HOW DO I RECORD FREESAT FROM TX-L42D25B TO DMR-EX773EB
  • 909 Answers
Link the output from freesat box to input on recorder, output from recorder to TV. if you have the correct leads. then the freesat will play through the recorder to TV even when recorder is off.
To record, set record from the input, av1, or what ever it's called on the recorder.timer recordings can be set the same way, or if the system allows, record from input detect.
Posted on Oct 02, 2013
Fantasma
Afonso Martins
SOURCE: I have a Panasonic DMR-ES10EB
Pedro, gravadores de DVD não gravam de DVD players ou de VCR players devido a proteção tipo microvision, mas, eu penso que o DMR-ES10 pode fazer isto. Não o possuo, porém, tenho ouvido usuários brasileiros falarem que ele grava, sim. O meu DMR-E55Pls não grava.
Pedro, DVD recorders do not record from DVD players or VCR players due to protection type microvision, but I think the DMR-ES10 can do this. Not possess it, but have heard speaking Brazilian users it writes, yes! My DMR-E55Pls not record from... unles the files do not contain any protection.
Posted on Aug 29, 2010
Red and green vertical lines
Your problem appearing after the TV has 'warmed' up indicates a faulty electronic circuit board/power supply: if not under guarantee, it may not be cost effective to get it repaired.
Apr 06, 2014 | Panasonic Viera TX-L42D25B 107 cm 42" LCD...
How do I record two channels at once on a DMR-EX773EB DVD Recorder
I cannot find on online manual for this model. If dual channel recording an actual specification for the model? If it really should be able to record two channels at once then it may be similar to the DishNetwork DVR. It has one input but internally splits and creates two different outputs for two different channels.
Check to see if there is a mode setting for single/dual. You will need to set it to "dual". The Dishnetwork DVR has what it calls TV1 and TV2. You can record to TV1 but cannot watch a different channel on TV1 while it is recording. You CAN however watch and record a different channel on TV2 while TV1 is recording. (and vice versa). You can also record two shows while watching other recorded shows.
I'm guessing that you may need to look for some recording options to be able to record two channels at once.
Mar 21, 2011 | Panasonic Televison & Video
How do i connect my samsung dvd recorder sh853m to my free sat box? Also is it possible to record a channel from free sat onto my samsung recorder while also watching a different free sat channel.
If it's a Standard-Definition (SD) FreeSat box then a SCART cable would be the normal method of connection to your DVD recorder. This would connect to the SCART/EXT OUT socket on the back of the FreeSat box and the SCART/EXT IN on the DVD recorder. However, this depends on whether your FreeSat box has multiple SCART outputs and whether you are using a SCART cable to connect to the TV.
If there is no spare SCART output socket on the FreeSat box, then you need to use an alternative connection which is common to both devices, i.e. co-axial, and make sure you are connecting from an OUT socket on the FreeSat box to an IN socket on the DVD recorder.
If you have a FreeSat HD box, then you need to connect it to the DVD recorder using an HDMI cable or another cable type that will carry an HD signal.
You will only be able to record from a different Satellite channel if you have a Dual LNB with 2 feeds to the FreeSat box. The LNB is the receiver that attaches to the arm on the satellite dish. You can determine whether you have a Dual LNB as you will have 2 cables from the Dish to the FreeSat box. They may be joined as one cable, but there will be 2 F-plugs (threaded co-axial plug) on each end.
If you don't have 2 cables then you will only be able to record the same channel as you are watching. To record another channel, you need a FreeSat box that supports this feature and each channel needs also a separate feed from the dish.
Hope this helps. If you need any further assistance please post back with the brand model number of your FreeSat box and details of the connections you are using between the FreeSat box, the TV and the DVD recorder.
Regards,
BElectric
Dec 29, 2010 | Samsung Televison & Video
I have just purchased the panasonic dvd freesat recorder. how do i connect to tv
jus like every electrical circuit your combo player will b colour coded. the video out is usually a single jack on its own in da colour of yellow. now da audio is a bit more difficult but very easy to connect.if u read da back pannel u will read audio out wic u will connect da remainin cables. the colour coding for audio is either red and white or red and black
Aug 26, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
I have a Panasonic DMR-ES10EB DVD recorder and want to know if I can record programmes from my new Panasonic TX-L32G20B TV
Aug 25, 2010 | Panasonic DMR-E55 DVD Recorder
Can i set up my blu ray recorder DMR-BS750 without
The purpose of that freesat to bo able to record/playbak 2 channels at the same time. But you still need a satellite dish pointing to the satellite in the sky so it can work.
Jan 13, 2010 | Panasonic Televison & Video
Panasonic DVD Recorder DMR-EZ48VEB. Colour missing
I have a Panasonic DMR EH50 DVD recorder and have just discovered this evening that everything on it is displayed in Black & White (tuner, recordings, menu, dvds etc). Yesterday everything was working in full colour. I have checked all my leads and have no solution to this problem and also need help.
Jan 03, 2010 | Panasonic Televison & Video
Setting a new Panosonic TV
If it has no freesat tuner then you can only record what the TV is viewing/tuned to as an output from the TV.
Mar 21, 2017 | Panasonic CT-27SF36 27" TV
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
