Screen has crack and picture has lines - Sony Bravia KDL-46EX521 Internet TV Compatible Full Motion Articulating Swivel Wall Mount Bracket This Full Motion Mount Will Extend 26 Inches & Easy to Install TOP SELLER
Display panel fault. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
tha't an easy task to handle
See the pictures below
if your whole screen shows an image and the cracks are in front of it then its just a cracked digitiser
if you dont see the whole image and tyou see horizontal and vertical line or an image like spilled liquid then your Lcd is also cracked too
this is a broken Lcd (the screen is distorted by the lines or no picture at all)
this is just a broken digitiser (the screen below the broken glass works fine )
If the set got struck on the screen the screen itself may not be cracked but the panel (The entire front where you view the image is called a display panel) may be damaged inside.
A good photo would tell me--usually it will look like a odd burst or lines and or colors more pronounced where the screen was hit and spreading out in a uneven pattern---Google for "Pictures of Damaged LCD or Plasma screens"
Yes, thats correct. If lcd tv screen got hit by some thing then lcd panel got cracked and does show distorted lines or cracks instead of picture and lcd panel have to be replaced that would cost you 70% to 80% of new tv price. New TV is better option.
If the main PCB is not cracked too bad, it should not be expensive to repair. You have lost vertical deflection causing the flat line.There may be a crack at the flyback, where the vertical IC gets its operating voltage, or a crack at the pins of the vertical IC itself.
