Question about Dell Computers & Internet
How do i get the original color back on my computer? somehow i changed it and i need it back to normal.
    New Friend:
  • 5 Answers
If you are taking about you home screen, (1) right click on personalize (2) Click on Desktop background (3)click on Desktop Background Color, and choose what color you like and click OK. Hope this helps. Good luck!
Posted on Oct 01, 2013
6ya staff
SOURCE:
How do I adjust the color on monitor?
Instructions
  1. PC Monitor
    • 1Check the color balance options on your monitor. Typically, there is a button on the monitor itself that can be used to enter the Settings menu and configure color. The color balance may have somehow been changed, resulting in the pink image.
    • 2 Calibrate the color system for your monitor through Windows. Press "Windows-X" to open the Power User menu and select "Control Panel." In the Search bar, type "calibrate display" and click on "Calibrate Display Color" when it shows up. Provide your administrator password or confirmation if prompted.
    • Sponsored Links
    • 3 Check to see if the cable connecting the monitor to the computer is loose by lightly jiggling the connector at both points. If it's loose, this could be the cause of the display error. Secure the connection and see if the issue has cleared up.
    • 4 Check the connectors themselves for bent or damaged pins. A damaged pin can cause a faulty connection, which can lead to errors like a pink-tinted screen. If the pins are just bent, you can try to bend them back into place with a pair of needle nose pliers. If they are otherwise damaged or missing, you'll have to replace the cable itself.
    • 5 Perform a factory reset of your monitor if replacing the cable has not repaired the issue. Instructions for a factory reset vary from one model and manufacturer to the next, so consult your owner's guide for detailed instructions.
    • 6 Connect your computer to a different monitor if the problem persists after factory reset. If the problem persists with a new monitor, the issue is likely with your video card. If this is the case, consult the card's manufacturer for detailed diagnosis and assistance. If not, your monitor may be damaged and incapable of rendering a properly colored image. Take it to a repair professional for repair or replace it.
Read more : http://www.ehow.com/how_8446307_fix-color-pink-hue-everywhere.html
GOOD LUCK.
May 11, 2014 | Acer V193w LCD Monitor
Why is my printer offline?
First you need to wake up your printer; second, if your computer is not directly connected to this printer, you need to change the IP address (by detecting this printer; use "Add printer"). Somehow, if the printer power is turned off, it changed its IP address.
Feb 04, 2014 | HP Color Laserjet Cp3505n Color Laser...
@the monitor appearance changed to pink shade and we are not able to see in this colour pl give me a solution to sent it back to normal mode
probably the color setting of the monitor has been changed.
on the monitor panel press the menu button and go to the color option.
see if increasing or decreasing the RED GREEN and BLUE color options sets back the monitor to normal.
usually some monitors have a reset option also, by selecting it everything will get back to normal.
Aug 02, 2011 | Computers & Internet
I recently purchased a refurbished Dell. The computer's main font color is purple instead of black. Can this be changed?
Please let me know which operating system in installed on the Computer. Yes, it's possible to change back to it's default (O.S default) font color, but the way to change is little or more different.
I would also like to confirm which font looks Red, the text (names) on the desktop or the font's when typing in Microsoft Word or etc.. If you could somehow upload the screenshot, that'd be much appreciated.
Awaiting.
Nov 09, 2010 | Computers & Internet
I unplugged my Acer al1914 monitor from my computer and plugged a different acer al1914 in my computer and now when I transfer the screen from notebook to monitor it has a blue tint on the entire screen. I...
Check the color settings in the on-screen menu. You can choose between "Warm", "Cool" and "User". Maybe you used the "Warm" setting before and somehow it got changed to "Cool".
If this is not the case, you can try the "User" mode and reduce the intensity of the blue channel.
If even black areas show a blue tint, maybe running an auto configuration from the menu helps.
As a last resort, use the "Reset" menu item which resets all settings to factory defaults.
Mar 30, 2010 | Acer AL1914 19" LCD Monitor
Cant figure out color issue with computer.
Well...it's a Dell and even when it's well...it's still a Dell.
Have you tried the monitor on different system to eliminate the tower being the problem? Some have updated and/or rolled back drivers to help cure this problem, which seems to be a common issue with this LCD. Personally i think the contrast ratio is inadequate.
Good luck with your Delllll...
May 14, 2009 | Dell E176FP 17" LCD Monitor
My computer monitor has somehow turned its brightness all the way down, possibly due to me choosing a new screensaver which was already installed on my computer. Sadly, my monitor, an Emprex LM-1704...
Find yourself a dark room or wait for the night to come. The darkest monitor adjustment could somehow reveal some light when there are no other light source available.
You may also hook a conventional CRT monitor and make your changes (such as bringing your computer back to its original settings). The darkest adjustment in CRT monitor could still render discernible displays.
Sep 09, 2008 | Computers & Internet
Light blue color to the screen
It's possible that the screen is going, it's also possible that the inverter is going. An inverter can cause the same color change problem. It's definitely one of the two.
Jun 09, 2008 | IBM ThinkPad T21 2648 Notebook
Scanner started scanning color photographs in black and white
The problem is simple.Someone or somehow the "TYPE OF ORIGINAL" option on ur SCANGEAR CS window.Set it back to "MAGAZINE" or "PHOTO" and it should scan in color.
Oct 07, 2007 | Canon CanoScan LiDE 70 Flatbed Scanner
Open Questions:
Dell [email protected]^+[1][email protected][email protected] Support Phone Number Tech Support Number Dell Printer Tech Support Number+1(855) 221-4867 time to gayo independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus s are compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus sare compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of technical support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. Antivirus s are compact and lightweight. Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. s are compact and lightweight.Dell Printer Tech Support Number 1(855)221-4867 is an independently owned and operated all kind of Tech support. There are a long series of Dell Printer s including latest technology and affordable price. Dell Printer produce All-In-One with basic printinG copying and scanning functions. s are compact and lightweight.anning functions. s are compact and lightweight dell printer configuration web tool dell printer default password dell printer document stuck in queue dell printer drivers dell printer drivers for mac dell printer error 004-321 dell printer error 009-340 dell printer error 016-302 dell printer error 016-302 dell printer error 0502 dell printer error 077-900 dell printer error 1203 dell printer error 900.57 dell printer error codes dell printer filter failed dell printer firmware error 900.00 dell printer firmware error 900.57 dell printer fuser error dell printer goes offline dell printer goes offline windows 7 dell printer goes to sleep mode dell printer green flashing light dell printer grinding noise dell printer installation dell printer jam problem dell printer job stuck in queue dell printer keeps calibrating dell printer keeps going offline dell printer keeps initializing dell printer keeps jamming dell printer keeps printing same document dell printer keeps saying downloading application list dell printer keeps saying left cartridge incorrect dell printer keeps saying offline dell printer keeps saying out of paper dell printer keeps saying paper jam dell printer network setup dell printer not communicating with computer dell printer not printing dell printer not printing black ink dell printer not printing color dell printer not recognizing cartridge dell printer not scanning dell printer not working with windows 7 dell printer not working with windows 8 dell printer not working with windows 8.1 dell printer offline dell printer only prints one page dell printer out of paper error dell printer pc life warning dell printer problems dell printer setup wireless dell printer tech support number dell printer there is a problem with the printhead dell printer troubleshooting dell printer will not print dell printer wireless setup dell printer wireless setup utility dell printer won't print dell printer won't print black
Jul 23, 2019 | Dell Computers & Internet
Computers & Internet Logo
Ekse
Alun Cox
Thomas F. Schneider
