I have a 2002 Suzuki VL 125 Intruder that will not start and I need a wiring diagram to trace where I am loosing the power.
I have a suzuki intruder vl 125 cc. battery ok engine turns over quick, petrol ok, just put fresh in. but no spark! bike's been stood up for a year, but was running 3 months ago, not very smooth, so i thought fresh petrol would cure it.
both plugs wet when removed, please can you help many thanks
You need to first check battery then check coils frm starter motor, if you do get it going your idle screw might need sorting, it should run at around 1500rmp
As with any problem you need a clymer book for your bike or you can disconnect the wiring harness(all of them one at a time)turn the key on and use a volt meter to make sure you are getting power.does the engine turn over?
I have igsactley the same problem.
And i dont have a clue whats wrong.
I have been told too look at the back off the coils some times the wires shake loose
I can not get a clymer manual for my bike
