SOURCE: Steam escaping from milk container
When you say change Oring do you mean the Oring in the capp. or in the machine?
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
SOURCE: Excessive water poured through shot
its possible someone held the buttons down to long enabling program mode.
Go to your local market and purchase a 3 ounce measuring glass. Place it where you place your coffee cup and hold down the small button, it should enable program mode. Stop it once it reaches 1 ounce or your desired amount.
Do the same for the large.
SOURCE: EAM3500S will not froth milk ?
Here's what I did... with great success:
If you've cleaned all the milk deposits from around the o rings and you still have a problem then its almost certainly the milk spout (the little pipe that directs foamy milk into your cup)
Detatch the spout and get a 2.5 mm drill bit and use it to clean all the milk deposits out of the part that plugs into the lid. Rinse through with water to clean away all the bits of hard milk.
[If you put water through the spout before and after, you will notice a dramatic difference]
Doing this completely fixed the problem for me (I had about 3 years of milk build up in mine!).
SOURCE: My Keurig is only 7 months old. It started
add a cup full of distilled vinegar and let set overnight.
then turn it on the next morning
this will remove all heavy scaling that has trapped the water from not brewing
