VIPER 7141V VIPER 4BUTTON REMOTE  7141V Logo
Dexter Garcia Posted on Sep 30, 2013
Program remote how do i program a new remote
joshua david gore
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 23 Answers
  • Posted on Oct 07, 2013
joshua david gore
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
23
Questions
Helped
3967
Points
43
Get in vehicle turn key on with new key fob in car, let run for 20 or so then turn off . hit the unlock button it should be programmed but not promising anything lol
2answers
DC Blue and PLUS reset ? remote lost, connect new but memory full
If you have lost your remote for your DC Blue and PLUS garage door motor and need to connect a new remote, but the memory is full, you will need to reset the motor to clear the memory before programming the new remote.
To reset the DC Blue and PLUS motor, follow these steps:
  1. Locate the reset button on the motor. It is usually located near the bottom of the motor and may be labeled "Reset" or "Learn".
  2. Press and hold the reset button for about 10 seconds until the LED light on the motor flashes rapidly.
  3. Release the reset button and wait for the LED light to turn off. This indicates that the motor has been reset and the memory has been cleared.
Once you have reset the motor, you can program your new remote by following the instructions in the manual. If the memory is still full and you are unable to program the new remote, you may need to delete some of the stored remotes from the motor's memory to make room for the new remote.
To delete stored remotes from the motor's memory, follow these steps:
  1. Press and hold the "Learn" button on the motor for about 10 seconds until the LED light starts flashing.
  2. Press the button on the remote you want to delete from the memory.
  3. Wait for the LED light on the motor to flash rapidly, indicating that the remote has been deleted from the memory.
Repeat these steps for each remote you want to delete from the memory until you have enough space to program your new remote.
If you are still having trouble programming your new remote or resetting the motor, you may need to contact a professional technician for assistance.
How do I re-program my Remote Control with automatic starter on my 2009 Town and Country Van
My experience with frequently-used vehicle remotes (any make) is this:
1. When relatively new or in good condition, if remote stops working, the button battery inside is dead or too low.
2. If battery is new, & remote still doesn't work, a solder joint on the circuit board inside may have come loose or broken.(You can try re-soldering using a low-heat pencil iron & thin RESIN-core solder -- even if you're not great at it, what do you have to lose?)
3. It's rather unusual for even an older, well-used remote to simply lose its programming.If this is the problem, it may be cheaper to buy a new after-market remote (or pair of remotes) that you can program yourself (only works with some brands & years of vehicles, so READ THE INSTRUCTIONS ON THEIR WEBSITE BEFORE BUYING AN AFTER-MARKET REMOTE), instead of going to the dealer for a normally HIGH-priced programming job.
4. Used OEM remotes that match yours exactly (check the part # of your remote & the used one you're considering) can often be purchased from a local auto wrecker (now called "auto recycler") for cheap ($5 to $10 is common), but will need programming.I always go thru the many they have, looking for one that appears new or like-new.
5. IF YOU MUST GET PROGRAMMING FROM A DEALER, usually it's the SAME PRICE whether you have 1 remote or several remotes/keys programmed at the same time.Since dealer programming is pricey, I always have 3-4 remotes and/or chip-keys programmed at the same time.(My dear wife loses chip-keys & remotes from time-to-time, so I keep a few spares on-hand.I've found inexpensive after-market chip-key blanks at some key cutters and/or auto parts stores, altho they still require programming after the copy is cut from yours.)
CAUTION
:Some OEM anti-theft systems require that ALL remotes & chip-keys be programmed/re-programmed at the same time, whether they're original, used or new.Determine this IN ADVANCE, so you know what you're faced with.The good news is that for those vehicle manufacturers, dealers normally don't charge more to program/re-program multiple remotes and/or chip-keys, if all are being done AT THE SAME TIME.
6. If all else fails & you MUST buy a new OEM remote (which will require programming), try 2 things -- First, see if the dealer will make you a package deal on buying the remote (or 2 remotes, or a remote & a chip-key) AND doing the programming for a lower combined price.Second, it may be cheaper to buy a new OEM remote from a dealer who's had one in stock for a long time & wants to blow it out (or buy from online OEM seller) & then pay the normal programming price.See the CAUTION above.
There are lots of options here, so hopefully something is useful to you.
2answers
I can't get my older garage door remotes to program with the new unit.Do I have to buy new remotes?
SORRY TO SAY.THE ANSWER IS YES.
THE NEW OPENERS ARE NOT ON THE SAME FREQUENCY.
YOU CAN PURCHASE REMOTES THAT WILL WORK WITH BOTH OLD AND NEW OPENERS (DUAL FREQUENCY).
BUT, OLD REMOTES WILL NOT WORK WITH THE NEW OPENERS.
Unable to program new sender to receiver. The receiver should flash three time but the diode lights up a fourth time for a period and the sender is not programmed.
This is the procedure for remote to remote programming, try this!
Step 1. Using a old programmed remote that is already up and running.
Step 2. Press the button for five seconds of the new remote you want to activate and release.
Step 3. Press slowly three times the old remote button.
Step 4. Press the button again slowly and release control.
Step 5. Verify that the new remote works.
Toshiba Color Television 36A43 Lost the original remote and purchased a universal remote. Tried to program using all four systems to no avail. I require the universal remote code to program for this TV
Place one remote on table, place other (new) remote facing old remote, then push the program button on new remote, remotes IR screens has to face each other to make this work. and if you've tried to program the new one before, you will have to clear the new ones memory first. Good luck.
1helpful
Need to program new remote 3.2IR
In your Dish Network instructions it will show you how to program your TV to the Remote
Have new keyless remote, how do i program it? 2006 Uplander
The dealer should be able to program it for you. When I bought mine, the dealer could not find the keyless remote, they took another remote for a different van and they just programmed it right there and then.
3helpful
How to program a new remote keyless entry for 2002
1. Press LOCK button 5 times at 2 second intervals to resynchronize remote.
2. Insert key into the ignition switch. Turn ignition to the RUN position (as far as you can
go without cranking engine). Wait for ignition chimes to stop.
3. Using the working remote, press and hold the UNLOCK button on the remote for 4 to 10
seconds.
4. Within the specified 4 to 10 seconds, continue pressing the UNLOCK button and then
press the PANIC button ( on the programmed remote ) for 1 second and release both
buttons. A chime will sound to indicate that the remote programming mode has been
entered ( allow 3 seconds for chime to sound ).
5. Within 30 seconds of the chime, press and release the LOCK and UNLOCK buttons
simultaneously then press and release just the UNLOCK button on the same remote.
A chime will sound indicating the remote has been programmed. Press and release
the LOCK and UNLOCK buttons simultaneously and then press the UNLOCK button on
each new remote you wish to program at this time. Locks will cycle after each additional
remote is programmed.
6. Turn the ignition OFF and remove key.
7. Test Remotes.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
2answers
How do i program my remote
I went to the Comcast website and there they have directions to program their remote. The only problem is there are several remotes listed and it is difficult to pick out the one you have so it is a bit of trail and error until you find the right directions.
Top Viper Vehicle Parts & Accessories Experts
oneStan
oneStan
ZJ Limited
ZJ Limited
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
