SOURCE: my computer starts up it logs off straight away
ok
when u power up the computer press F8 key then u see safe mode then enter in safe mode.
then uninstall norton from it
SOURCE: My Fujitsu-Siemens Lifebook S7110 display
The display may be going black because of IC's getting heated up,contact ur Provider and get the screen replaced if using an external monitor is irritating
SOURCE: I have an e2010 fujitsu lifebook. When I turn the
Insert your Windows install CD and boot from it. When it asks you to select either install a new copy or Repair current OS. Select current OS, you might lose some data but it might fix the starting problem.
SOURCE: how to remove hard drive fron siemens lifebook
Turn Laptop over, looking at it so the battery is at the top edge. In the bottom left hand corner is a rectangular access cover with some air vents, unscrew the 2 screws and take off the cover, you my need to use a flat screw driver to lift it, you should now be able to see hard drive. Remove any screws holding drive and slide it either left or right to to disengage it from its connections and lift it out.
