Refrigerators Logo
Question about Refrigerators
Ice Maker WR30X0327 Freezing Over I have an
Ice Maker WR30X0327 Freezing Over I have an unusual problem with this ice maker. The incoming fill tube passes into a white plastic compartment on the back of the ice maker. Water flows into this compartment and from there the water drains out into the ice maker tray. When making lots of ice this white compartment somehow freezes over and blocks the incoming water from draining into the ice maker. On the next cycle the incoming water then flows over the top of the compartment into the freezer below and makes quite a frozen mess. I take out the ice maker and remove the ice block from the white compartment and everything is fine again for a while, then it happens again. The fill tube does not freeze unless I don't catch the problem in time, at which point the ice build-up blocks the fill tube and then it also will freeze solid. Since the ice maker itself makes cubes fine when the white compartment isn't frozen over, I don't see how I can fault the ice maker unless there's something happening I don't understand. The temperature setting of the freezer is above the mid-point on the control so I don't think the temperature of the freezer is too low. Has anyone experienced this problem and solved it?
Posted by Gary Oliwa on
John Hong
  • 787 Answers
Have you tried insulating the fill tube ?
Posted on Mar 03, 2017
Julia Wood
    Habit-Forming:
  • 158 Answers
We have extremely hard water in the East Mountains of NM. Our refrigerator Ice Makers only lasted about a year before the Calcium from the underground Calcium just killed them. I solved the problem by buying, from ebay, a small restaurant ice-maker. I Always fill it with filtered water, and it has been chugging away for years. Our water tested Harder than an Hot-tub maker had ever seen, even after going through our old, Sears, water-filter. Ergo - how hard is your water? Could that be the problem. Just a thought.
3 Related Answers
Anonymous
  • 31 Answers
SOURCE: Whirlpool refrigerator Model # ETIRHMXKT
can be worn gaskets...clogged pipes or coolant leakage.
tell me about
Posted on Jun 22, 2008
Controlfrk
Controlfrk
  • 304 Answers
SOURCE: kitchenaid ice maker dripping and freezing down freezer shelfs
Tube sometimes freezes because of minerals in it hold one droplet at a time until buildup freezes solid. Replace tube first. Water valve allowing some droplets through can also cause this. Tube first-less expensive.
Posted on Aug 23, 2009
Anonymous
  • 64 Answers
SOURCE: ice freezes into one solid block and won't dump out of the tray
remove cube tray from ice maker. clean with limeaway adn rinse. Spray with a light coating of PAM cooking spray. wipe dry and reinstall. be careful not to damage the sensor ( in center of tray)
Posted on Aug 26, 2009
1helpful
I have a KitchenAid side by side fridge, type 25SSA, water is leaking from bottom of ice maker down front of freezer and into ice bin, how do I stop leak?
Is the refrigerator and the ice maker level? Does it appear that the ice maker is over filling or slowly overflowing due to a leak in the Click here=> W10408179 Refrigerator Water Inlet Valve? Look in the rear of the ice maker where the water fill tube enters the ice maker do you see water freezing and running down to the ice bin from there? Let me know.
http://appliance911seabreeze.com/
I have a ge tfx20jr side by side the ice maker is not dumping the water fills the tray but it won't dump
That is an electronic control ice maker and possibly worked hard for the last few years. If the ice maker will not respond to the full arm or switch being on to empty the cubes about the only thing you can do is replace it=> WR30X0327 Ice Maker Assembly
I am here if you have questions, John Tripp Appliance 911
Contact me here.
Water flow tube on ice maker leaking by causing ice blockage
When the ice maker calls for water, the valve sends water to the ice maker in the appropriate amount and then shuts off, sending no more water until the ice maker calls for it again. If the water fill line is freezing up, this will cause a leak the next time the ice maker calls for water. The water has to go somewhere. The problem is more than likely the the water valve. It is not shutting off completely and it is allowing a small trickle of water to be constantly sent to the ice maker. This causes the fill line to freeze up and clog. Replace the water valve and defrost the water fill line and solve the problem.
1helpful
My freezer is not freezing anymore please help as can not afford a new one ..thank you
Follow the steps mentioned below to solve the problem:
First remove the ice bin and look inside the mold of the ice maker to see if it is full of ice. If the ice sensing arm is down ( on position) and the ice maker is full of ice, there is a failure inside the ice maker and the ice maker should be replaced.
If there is no ice in the ice maker, look at the fill tube on the rear of the ice maker. If the fill tube is frozen up the ice maker can't fill.
You can defrost the fill tube with a hair dryer.
The water valve on the rear of the refrigerator supplies water to the water dispenser and the ice maker. Since the water dispenser is working, the only line that could be blocked runs up the back of the cabinet and attaches to the fill tube for the ice maker. The water valve could be bad and not sending water to the ice maker.
If the fill tube freezes again you should replace the water valve.
Hope this helps.
Shane
1helpful
Water is leaking out of ice maker and freezing up where cubes are
Sounds like water valve is not closing all the way after the icemaker calls for water. This is because sediment in water builds up on valve seat therefore letting water pass through. Suggest replacing fill valve. Crescent shaped ice....ice maker on needs 4 ounces to fill icemaker, so any more than that will spill out.
Ice maker making hollow cubes
check your incoming water pressure, change the water filter recently? hollow ice cubes is a sign of low water pressure
Water to my ice maker freezes in metal tube
ON MOST ICE MAKERS, THERE IS A LARGE WHITE GEAR ON THE FRONT OF THE ICE MAKER BEHIND THE COVER.
THIS GEAR HAS CIRCUIT TRACES ON IT THAT WILL BURN THE PLASTIC FROM ARCING FUSING THE WATER FILL CIRCUIT TO ANOTHER ONE CLOSE TO IT. THIS WILL CAUSE THE FILL TIME TO TRIPLE FROM THE 7 SECONDS TO ABOUT 20 SECONDS. THIS WILL OVER FILL THE ICE MAKER AND POUR DOWN INTO THE ICE BIN. THE ONLY SOLUTION IS TO REPLACE THE CONTROL MODULE OR THE ENTIRE ICE MAKER.
Frigidare FRS23KF6CB manufactured 03/07 ice maker water fill wont shut off
There is a float in the icemaker which controls water height. I'm going to bet the float is jammed or the switch it controls is bad.
Ice Maker not getting water Kenmore Side/Side 53642
2 things that could be wrong with these ice makers (Red light is solid, but no water to ice maker and My ice maker does not make ice and water is appearing on the floor). Either you have a defective water valve or your incoming tube is iced up. 2 ways to check:
1. Check your ice maker valve which is at the bottom of the refer. To find follow the water line into the back of the refer. it should connect to the water valve. Check and make sure there is 125V to the valve when it is in fill mode. Or look for and open condition at the solenoid (you check for open with a meter). When checking across the leads you shouldn't get any meter movement at all.
2. Remove the ice maker or the port that comes into the ice maker on the back of the refer (it is usually held in with 2 screws). Make sure it is not frozen up. If it is sometimes if you take regular insulation and pack it into the area where the port comes in that can stop the freezing problem.
Good Luck!
God Bless
Open Questions:
Top Refrigerators Experts
Marvin
Marvin
john h
