Question about Minolta Office Equipment & Supplies
Fiery driver bizhub c450
I am trying to run a black toner job - 12 x 18 and can't seem to get it black enough. Any suggestions?
Posted by Richard Mullins on
Norman J Weimar Jr
  • Minolta Master
  • 6,960 Answers
Changed the media type? Try different thick paper? Try printing directly to the copier instead thru the Fiery
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Jan 24, 2015
5 Related Answers
Anonymous
  • 589 Answers
SOURCE: bizhub C450 error (C-0212)
C0212 is a LCT (large capacity tray) shift motor, or lock release failure (they both use the same code)
Open the lower paper tray, and look for anything unusual.
Sounds like the paper was loaded incorrectly, and the tray tried to lift.
Posted on Feb 10, 2008
Anonymous
SOURCE: proplem with KONICA MINOLTA bizhub C450
c-3451
Posted on Nov 10, 2008
Anonymous
  • 90 Answers
SOURCE: Ocr scan for Bizhub C450
according to what I read on the C450 biz hub, in order to do OCR you need to use the option that scans to SMB, that sends the scanned documents to your computer on the network. You can then process the documents on your computer with the OCR software program so you can edit the finished documents. I did not see anything that indicated the Bizhub had OCR software capabilities built into the unit. Regards, rcampsr
Posted on Feb 20, 2009
Anonymous
  • 12 Answers
SOURCE: Imaging Unit Problem with bizhub C450
On the end of the image unit you will find a white bit of plastic with a small screw in the middle, make sure this screw is tight and then reinstall the units(give the units a bit of a shake too)
Posted on Apr 06, 2009
taminol
taminol
  • 62 Answers
SOURCE: Printing labels on bizhub C450
Hi nwillett,
Yes and no, sorry if that doesn't make much sense.
For years Minolta recommended Avery labels, but these days they recomment labels manufactured by Howard Smith Papers, their website is http://www.hspg.com/
The thing with labels is always to use the one your copier service company suggests. Otherwise they'll invalidate you contract and you'll be liable for callouts and repairs caused by using Avery labels.
However, Avery labels are good and I have experienced very few problems with them I pressume you using the lables in the correct orientation and also using the manual bypass to feed them.
Regards
Taminol
Posted on May 26, 2009
Bizhub C450 strange printing problem. Green data LED is flashing but nothing happens.
Did you try to change the IP address of MFP. Please change IP address of MFP and connect the PC you are sure not giving any problem. If its works fine then connect rest of the remaining PC's
Nov 15, 2014 | Konica Minolta bizhub C450P Laser Printer
Bizhub c450 what is job has been done improperly check the log
Go to "job list" select job high lite then touch details what does it say????
Feb 03, 2014 | Konica Minolta bizhub C450 Scanner
Bizhub c450
On your printer settings on your computer when you select to print there should be a box that says only use black ink. Try that first and if it still prints in green you may have them in the wrong ports.
Aug 18, 2013 | Office Equipment & Supplies
Log in error with bizhub c450
We have been having this problem and I am trying to find an easy way to push the fix out to all users automatically. What I have found is that the driver automatically inserts the Windows network login name as the user name under "Authentication/Account Track" insteead of the "Public" user. Even though I have it set to Public User in the driver on the print server (and defaulted to Grayscale), It has to be manually set for each user on their PC's driver. More often than not, it also has to be set in the Printing Preferences in the application the user is trying to print from (Ex. MS Word, Acobat Reader, etc.).
Mar 05, 2012 | Konica Minolta bizhub C450P Laser Printer
I have a bizhub C450 Fiery printer and it was working fine on our old network, but then we changed networks and are trying to set up the printer on each individual computer. I've downloaded all the...
Well you need to log in as administrator reset the IP address the mask and gateway. it is still on the old net work and was set as static IP address which mean it not set up for DHPC
Nov 24, 2017 | Konica Minolta bizhub C450P Laser Printer
Hi, on Konica-Minolta Bizhub C450 printing speed is very slow. Attached to Ethernet, Data via TCP/IP. Speed 100 MBit fullduplex. Sending a full color A4 page with 300 dpi; f. E. from...
Am having little Challenge if I send job to printer Bizhub c451. D job will enter printer and it will wrote System Printing and it will not print
May 10, 2017 | Konica Minolta bizhub C450P Laser Printer
Bizhub C450
sounds like the wrong image unit. Oce and ollivetti have the same machine and take the same image unit but with a different chip. Make sure it is a genuine konica minolta image unit. If need be try putting the chip from the old unit on the new one and see if lays down the colour
Jul 10, 2008 | Konica Minolta bizhub C450P Laser Printer
42 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ed
Ed
CheckitRight
CheckitRight
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
