Whenever I am looking webpage or document , page went down to bottom automatically without pressing END key ? How can I disable END key
SOURCE: Asus w2v laptop keyboard problem
Press Fn + Numlock. You have the number lock on, but laptops don't have a number pad. So it re-assigns these keys to overlay some existing ones. Once your number lock is turned off you should be ok.
SOURCE: fn key on dell inspiron 1501 keyboard not working
Sounds like your number lock is on. Find the key with blue lettering that says 'Num Lk' (or something very similar). Press Fn and that key, and your number lock will be turned off and your keys will go back to normal.
Hope this helps.
SOURCE: Fn key problem with Gateway notebook
Hey there, this is an easy fix, just press the num lock key:) let me know if for some reason that doesn't work
seth
1. Enter BIOS Setup
1. Press the Esc key while powering on the computer.
2. Press the F1 key, when prompted.
2. Change the Virtualization Technology option
The Virtualization Technology option is in the OTHERS configuration pane on the right-hand side of page 1 of the BIOS system setup.
1. Press the O key to select the OTHERS pane, and use the down arrow key to move down and select the Virtualization Technology setting.
2. Set it to Disabled.
3. Change the Configuration option
The CONFIGURATION option is on the upper left-hand corner of page 2 of the BIOS system setup.
1. Press the PgDn key to go to the second system setup page.
2. Press the O key to select the Device Config setting and change it to All Devices.
4. Change the Display option
The DISPLAY configuration option is on the bottom left-hand side of page 2 of the BIOS system setup.
1. Press the D key to select the Power On Display setting and change it to LCD+Analog RGB.
5. Save the changes by pressing the End key and then the Y key to. Be sure not to press the Home key -- which restores the default BIOS settings.
it automatically go to end
