SOURCE: clicking noise sony bravia kdl-40v3000
http://forum.ecoustics.com/bbs/messages/2/176039.html <-- Check that out.
Also I have a Sony Bravia and it clicks while it is on as well. I read that forum and some people said to disconnect the cable box for 10 sec. and then some said it was the heat from the summer.. i don't know.. I just turned my tv off and then back on and it stoped. I read this is happening with all kinds of TVs....
SOURCE: We were watching tv on
sounds like the lcd control board malfuntioned. call sony and im sure they will have you bring it to a repair shop at no charge
SOURCE: vertical lines on sony kdl-46v3000 bravia lcd tv
i have the same problem, apparently the LCD panel needs to be replaced and this will cost more than the tv is worth... Advice is to not buy a sony again, because this is a common problem and they wont extend the warranty, even if its 2 weeks after it runs out...
SOURCE: sony bravia kdl 32l4000 - color bars running vertically on screen
In most cases is the screen is covered with vertical lines all the way accross the screen then the T-Con module is at fault. The t-con board is replaceable without having to replace the entire LCD panel which would usually make it cheaper than replacing the TV. The part number I come up with is 1-857-213-11. Please take a moment to rate my answer. Thanks...
SOURCE: sony bravia lcd
Sounds like a possible T-con board failure. Which would need to be done by experienced tv repairman
