Question about Belkin (F5D7230-4) Router (587009)
How do I enable IPSEC Passthrough on this wireless router?
Posted by Mark J on
Techbelkin
    Sergeant:
  • 358 Answers
Look in the settings of the Belkin to see if you can enable VPN Pass-through.
Try disabling some of the firewall functions on the belkin to isolate the issue and turn the rest back on.
If for some reason this model doesn't work even after the above, try changing the VPN client's connection settings,there are only two to choose from... (click modify on your connection entry, go to the Transport tab > then choose from:
IPSec over TCP and IPSec over UDP (port 10000)
Posted on Nov 05, 2013
I have to connect to work via a VPN, when I connect, the wireless becomes disconnected... after I disconnect from the VPN the wireless connection comes back. would the router cause this?
Check the Advanced tab of the N300's Firewall settings to see if VPN passthrough is enabled. If it's not, the firewall will cut off VPN communications.
You may also need to run the VPN Wizard on the N300.
Here's the manual:
http://cache-www.belkin.com/support/dl/F9K1004v1%20manual%20-%20revA00.pdf
Feb 15, 2015 | Belkin N300 Wireless N Router
I am having difficulty connecting to Cisco VPN, could the router be interfering with this
The router could be blocking it. On your belkin router, check to make sure that ipsec vpn pass through is enabled.
Mar 18, 2011 | Belkin Basic Wireless Router
I have a D-Link DVG-G1402S router, I'm trying to setup VPN connect for a windows VPN server, which inside the network. I tried use modem directly connect to the server, it work, so it process my...
The router's PPTP passthrough and IPSec settings assume that you're connecting to an external VPN server on the public side of the network, but it sounds like you're hosting your VPN server inside your local network. If this is the case, you may just want to have your windows VPN box in a DMZ, or get a router that you can exert more control over. Be wary, if you're doing this at a residential location, your internet provider will probably block or "shape" this type of incoming traffic to your local network.
Mar 05, 2011 | D-Link DVG-G1402S Wireless Router...
How to set password to avoid others using my wireless setup?
Enhanced Security with WEP, WPA/WPA2 and Firewall The NBG-417N supports the latest, most secured WPA2 wireless encryption with its one-button encryption setup. It also supports commonly used 64/128-bit WEP, WPA encryptions. It provides stringent protection for wireless transmissions. In addition, the NBG-417N is equipped with firewall features including NAT, Stateful Packet Inspection (SPI), Denial-of-Service (DoS) and VPN Passthrough (IPSec, PPTP, L2TP) to prevent attacks coming from the Internet.
Feb 16, 2011 | Zyxel NBG-417N Wireless Router
New Modem with a router for wireless Laptop
Some routers have a kind of built in firewall. You need to let the router/modem that it is okay for it to let this information pass through it. Here are your instructions
Overview
Follow the steps in this chapter and use the Gateway’s web-based utility to configure the Gateway. This chapter
will describe each web page in the Utility and each page’s key functions. The utility can be accessed via your web
browser through use of a computer connected to the Gateway. For a basic network setup, most users only have to
use the following screens of the Utility:
• Setup. On the Setup screen, enter the settings provided by your ISP.
• Security. Click the Administration tab and then the Security tab. The Gateway’s default username and
password is admin. To secure the Gateway, change the Password from its default.
There are seven main tabs: Setup, Wireless, Security, Access Restrictions, Applications & Gaming, Administration,
and Status. Additional tabs will be available after you click one of the main tabs.
Setup
• Setup. Enter the Internet connection settings on this screen.
Wireless
• Basic Wireless Settings. You can choose your wireless network settings on this screen.
• Wireless Security. This screen allows you to choose your wireless security mode.
• Wireless Network Access. This screen displays your wireless network access list.
• Advanced Wireless Settings. On this screen you can access the advanced wireless features.
• WDS. The wireless distribution system feature is accessed on this screen.
Security
• Firewall. This screen contains filters and the Block WAN Requests feature. Filters block specific internal users
from accessing the Internet and block anonymous Internet requests.
• VPN Passthrough. To enable or disable IPSec and/or PPTP Passthrough, use this screen.
Jan 20, 2009 | Linksys Computers & Internet
DLink DI-624s - can't get Cisco VPN Client to connect.
The "Virtual Server" setting is designed to give the general public access to a network resrouce (web/ftp/media server) on your internal network. If your the VPN concentrator is external to your network (meaning you'll have to use the internet to connect to it), then you won't need to define a virtual server on the DI-624.
You'll just need to enable the IPSEC and PPTP VPN Passthrough which it sounds like you've already done this. I've run into some ISP's that block VPN connections out of their network. If you have the ability, try to directly connect your laptop into your cable/DSL modem in place of your router and see if you can make a VPN connection, if not contact your ISP, if you can then verify you enabled the VPN passthroughs because your router is blocking them.
GIve it a shot and let us know your results.
Apr 26, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
Can't connect to AT&T VPN
I'll need to know what router you're using, make and model, for more specific help, but sometimes there is an option for IPSec passthrough. For example, on my Linksys Wireless Router WRT54G, there is a set of buttons under Security/VPN that are entitled IPSec Passthrough, PPTP Passthrough, and L2TP Passthrough. Since I don't know what router you're using, I can't tell you wether or not your router supports such functions or not, but if it does, you need to enable them.
Mar 04, 2008 | Trendware 54Mbps 802.11g Wireless AP
Cisco VPN Client won't connect
You'll want to enable the VPN transparency. In the router's administrative web interface, click the Security Tab, then the VPN Passthrough sub-tab. Cisco VPN's usually use IPSEC, so enable the IPSEC Pass-through and click "Save Settings". If this doesn't work enable the PPTP Pass-through as well and give that a shot.
Dec 31, 2007 | D-Link AirPlus Xtreme G DI-624 Wireless...
Vpn pass through problem with us robotics model 5461
login to the router and check these things
IPSec Passthrough: Enable Disable               PPTP Passthrough: Enable Disable               L2TP Passthrough: Enable Disable
Oct 29, 2007 | U.S. Robotics MAXg USR5461 (738168036790)...
Belkin (F5D7230-4) Router (587009) Logo
160 people viewed this question
Top Belkin Computers & Internet Experts
Mike
Michael Thomas
Michael Thomas
Lee Hodgson
Lee Hodgson
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
