Question about Bushnell Voyager 78-9945 Telescope
Where can I find the model number? - Bushnell Voyager 78-9945 Telescope
How do I find the model number for my Singer sewing machine? The model number is not on the machine. The serial number is B684078. It was made in the early 1900's.
  1. 1990 - present. For sewing machines manufactured since about 1990, look for the model number on the handwheel side of the machine near the on/off switch or the electric cord receptacle.
  2. 1970 - 1989. You will find the model number on the front panel of machines manufactured in the 1970s and 1980s.
  3. 1960 - 1970. ...
  4. Before 1960.
Machine Model Numbers ' Singer Sewing
How do find the model number for my Singer sewing machine Google Search
Nov 01, 2017 | Singer Sewing Machines
How i find the model number as per the serial number?
Hi Femil,
Usually the model number can be found in the sticker of the printer together with the bar code. You can check that sticker on the front of it. I have sample picture on how to find model number in printer. Hope it helps. dfc3d5c8-e5b8-4d6a-ac32-35bdf8c9a8bd.png
Mar 10, 2014 | Samsung Office Equipment & Supplies
Where is the water filter on a 1998 kenmore fridge
Here is where the confusion begins. When Kenmore says their model number, it is different than OEM numbers or original equipment manufacture's number's. Here is the deal with Sears when it comes to their model numbers. Sears buys all their products from someone else like Whirlpool, Maytag, GE and the list goes on and on. Then Sears calls their model number Kenmore Model Number=> Kenmore Model Number Locator's and the first three numbers are the models maker or who originally made the appliance Click Here for examples=> Kenmore Appliance Model Number Prefix's or Click=> Here once you have the correct Kenmore Model Number once you have that then you can find the parts for your dispenser. Your number will look like this for example only 363.235698 then go to Parts Direct or Repair Clinic and enter the correct Kenmore appliance model number and then search dispenser parts for that model numbers parts number. Hope I made this simple enough so if you need assistance I will be here to help you find that one small part you are searching for, Thanks, for understanding, Sea Breeze Once you find that 363.235698 example you will be well on your way!
May 05, 2011 | Kenmore 52642 / 52644 / 52649 Side by Side...
Sony Lens Cap for A100
The Lens cap model of the Camera depends on the model of Lens which you're using with the Camera. The model # of the Lens Cap for the Camera body and the lens differs. Few models and the details are given below:
55mm Front Lens Cap - G Series logo
Model Number: ALC-F55G
72mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F72Z
77mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F77Z
77mm Front Lens Cap - G Series logo
Model Number: ALC-F77G
α Rear Lens Cap
Model Number: ALC-R55
62mm Front Lens Cap - Carl Zeiss logo
Model Number: ALC-F62Z
49mm Front Lens Cap - Sony α logo
Model Number: ALC-F49A
62mm Front Lens Cap - Sony α logo
Model Number: ALC-F62A
62mm Front Lens Cap - G Series logo
Model Number: ALC-F62G
67mm Front Lens Cap - Sony α logo
Model Number: ALC-F67A
55mm Front Lens Cap - Sony α logo
Model Number: ALC-F55A
72mm Front Lens Cap - Sony α logo
Model Number: ALC-F72A
77mm Front Lens Cap - Sony α logo
Model Number: ALC-F77A
Please enter the SonyStyle webpage and check for the compatible ones for the Lens which you're using.
Thanks for using Fixya.
We wish you a happy holiday season..
Dec 21, 2010 | Sony Lens Cap for A100
What is the difference between Porter-Cable air compressor models that have a type 1 or type 2 behind the model#?
When searching for a tool or machine part at eReplacementParts.com, the product's model number and type number are always necessary to ensure an accurate part match. Even when a model or type number is only different by one digit, the parts for that model or type may not be compatible with other models and types.
Each manufacturer uses a different model and type number system, and manufacturers often call type numbers by different names. Some type numbers are especially difficult to find on the tool or machine.
This article provides explanations and pictures for finding model numbers and type numbers for several tool and machine brands, making it easier to order the right part for the right tool.
Explanations are listed below alphabetically by brand, but first, some additional information about model numbers and type numbers will be helpful.
Model and Type Numbers
Model numbers distinguish a manufacturer's models for a certain kind of tool within a given tool category (like drill/drivers and nailers). For example, two different power sander designs from the same brand would be distinguished by having two different model numbers. This is true for every b rand, that they separate major designs by model number.
However, manufacturers often update the design or features of a tool model, creating types of tools with the same model numbers. Most manufacturers distinguish the different types of a tool model from one another by assigning type numbers to them in addition to the tool's model number.
This is where it gets tricky. Finding type numbers for tools can be difficult because of the following reasons:
  • Type numbers can be very different from brand to brand. Sometimes an entire type number is just one digit or letter, and sometimes type numbers are very long numbers or long combinations of letters and numbers.
  • "Type numbers" go by different names, depending on the manufacturer. Some manufacturers call them type numbers, while sometimes they are called the: engineering number, series number, or bar code number.
  • Some model types are only distinguished by the year of the model.
  • Type numbers can be very difficult to find, sometimes located on the inside of a tool's housing (like some Ryobi tools). Fortunately, most type numbers are listed on the name plate with the model number.
  • When a manufacturer does not anticipate redesigning a tool or machine model, the first type of that model often does not have a type number assigned to it by the manufacturer. Designs that follow the first type will usually have type number designations.
  • Some manufacturers do not use a type number system at all, and instead change model numbers for each new design. In this case, the model number is the only number needed to match the right parts to the tool or machine.
In general, when searching eReplacementParts.com for the right model number and type number of a tool, the most important idea is just to match all numbers displayed on the webpage (under that tool's picture and name) with the numbers on the product.
On eReplacementParts.com, type numbers are displayed under the tool picture to the right of the model number. Sometimes type numbers are displayed in parentheses, like "(Type 1)" or "(0601916460)". Models that are not assigned type numbers will not have a type number displayed on the web page.
However, we will often list "Type 1" or "Type 0" for the first redesign of a tool model in a type series, even if the manufacturer does not list "Type 1" or "Type 0" on the name plate. This makes it easier for our customers and us to tell the first type apart from the rest.
Jan 19, 2010 | Porter Cable Air Tools & Compressors
I can not find model number or serial number on my roper gas dryer
NOTE: Some of the parts shown may not be for your appliance
The model number from your search was either missing or incomplete.
· Choose the best fit from the Model Number box to the left, or
· Check your appliance again to obtain a more complete model number
· To continue without a model number, use Narrow Your Search options
· Some models always have 3 numbers first, like this (123.456789)
// Model Number Locator Tips
1. A zero in the model number might be the letter O.
2. A lower case L might be a 1.
3. Some models have 3 digits and a period first, like this 555.66666666
Look for an aluminum tag--or a silver and white adhesive label in the locations illustrated below. The model number may be printed or stamped onto the tag and may be printed in different type sizes. NOTE: There may be partial model numbers on marketing stickers or in the owner's manual. These are often incomplete. For best results use the model number from the tag. Gas Electric Whirlpool Style 1 Gas Electric Whirlpool Style 2 Gas Electric GE Style GE Electric Maytag Style gaselectricwhrilpoolstyle1.jpg?ver=15
Jan 03, 2009 | Dryers
Bushnell Voyager 78-9945 Telescope Logo
42 people viewed this question
Top Bushnell Optics Experts
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
john h
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
