Question about Hitachi UltraVision 42HDS52 42 in. HD-Ready Plasma Television
Both hdmi ports on tv quit working at same time . worked fine in morning then nothing in afternoon. pluged dvd, cable,etc. into a differant tv and it worked fine so i know its the ports in the tv. any way to reset hdmi ports on tv?
5 Related Answers
Fujitsu
Martin Velazquez
  • 29 Answers
SOURCE: Hitachi P50H4011
You need configurate the DVD nad the salellite receiver output to turn on the HDMI out.
Posted on Dec 28, 2007
Anonymous
SOURCE: Set up
Seems that Hitachi DESIGNED the sound to cut off from the Audio Out jacks if you use component video or HDMI inputs. Has to do with copyright laws of the HD Video -- which makes it asinine that they disabled the audio as well, as it's not part of the copyright issue. Seems to me they were just lazy to disable the ENTIRE set of output jacks.
I am hoping to find some sort of hack for this (either firmware or severing/splicing a control wire). However, I can't find much information on this yet.
Posted on Feb 12, 2008
Anonymous
  • 103 Answers
SOURCE: HDMI Malfunction
You may have to activate that imput through your menu.Alot of plasmas have the ability to mute imputs.
Posted on Mar 03, 2008
Anonymous
SOURCE: says my hdmi ports are unsupported. they worked
Hay there i have the same problem and found out my LCD does not support xbox360 via hdmi have to use a componets cable not the standard av cable its the ones that go in to the YB,YR,PR slots like an RCA but they are actualy HD quality cables that will give same affect as using the HDMI cable and its hlf the price to!!. With the use of the components cable you will be able to veiw xbox360 in full hd up to 1080i or 1080p hope this helps as there many unanswered questions here! Who the hell runs this site? They arent very helpfull ay!!!!!!!!!!!!!!! Regards Matt Rocket
Posted on Oct 29, 2010
Eduardo Rodriguez
  • 61 Answers
SOURCE: I have a Hitachi p50v701 50" plama tv. Recently
I know it Sounds silly I also have a Hitachi TV and got issues with HDMI, I unplugged from wall for 15mins and turn it back, then I tried my PS3 and worked.
If not there is a firmware update on the website however it needs to be uploaded by a "technician" via USB drive mine has a USB port but there is no update for mine.
Let me know if it works
Posted on Mar 16, 2011
Vizio E470VLE HDMI inputs not working
its the antanna don't go on your roof you probs bumped it
Aug 31, 2016 | Vizio E470VL 47 in. HD-Ready LCD TV
Sony KDL-40NX711 HDMI PORTS STOPPED WORKING. EVERYTHING ELSE WORKS FINE. WHAT WOULD CAUSE THIS TO HAPPEN?
Sounds like everything works. Your remote has an input menu. Have you cycled it around to the right component? i.e. HDMI1 or HDMI2, or DVD, even PC?
If not, try that.
Feb 09, 2016 | Sony Televison & Video
Sharp LC-32sb24u hdmi not working
You have to tell the TV which HDMI input to use. ie you should be able to press a button on your remote to do this. On my tv we can choose between 4 different HDMI inputs via the remote.
Dec 23, 2013 | Televison & Video
Denon AVR-4806 HDMI problem
Check which port you have the HDMI cable connected to, then go into the menu on the TV, look for it on screen and Enable it .
Good luck
Nov 16, 2013 | Denon AVR-4800 Receiver
I cannot get the Input 3 HDMI port to work. The Input 3 Componet videoworks, but when I unplug the componet video and put in HDMI port nothing works. I do have something else in the HDMI Input 1 port...
Hi.
To start ensure that each time you connect or disconnect the HDMI ports both TV and connected device are off.
Also ensure that HDMI input is active, as detailed here.
HDMI connectors carry voltage, and connecting the HDMI cable while TV or device is on may easily damage the HDMI port, making it unusable.
The HDMI 3 and Component 3 are separate input. The component input may work, and HDMI port may still be defective.
To test the port do the following:
Disconnect TV power cord, and connected device (eg. Receiver, DVD etc.).
Leave units disconnected for five minutes.
While power is disconnected, test connecting on port three a device that was previously working on HDMI 1. Also use a cable that you know is working.
Connect back power with HDMI cable already connected. If HDMI 3 is still not detected, then the port is defective.
In that case ring Pioneer at the number listed on the owners manual.This model is often advertised as only two HDMI inputs. Call Pioneer to ensure the third port can be enabled.
Dec 26, 2009 | Pioneer PDP-4350HD 43 in. Plasma...
Surround Sound works with DVD, but not with TV, cable, etc.
dont know if it helps,but try connecting audio cables to the dvd from tv. worked for me !
Jan 05, 2009 | Sony DAVHDX265 System
Hitachi UltraVision 42HDS52 42 in. HD-Ready Plasma Television Logo
21 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
