Question about Harley Davidson Lands Phones
Starter stays engaged - Harley Davidson Lands Phones
Posted by keithwhitm1 on
  • keithwhitm1 Oct 01, 2013
    Starter gear will not retract.
starter button on handlebar could be bad or stuck.
Apr 07, 2014 | 1995 Honda GL 1500 SE Gold Wing
When testing starter out of truck works fine, put starter in truck and under load starter stays engaged, rip
Either the solenoid is getting power when it should not be, or the starter drive is not aligned with the flywheel.
Jan 18, 2014 | Cars & Trucks
03 Oldsmobile Silhouette 3.4L Starter stays engaged at times.
Sounds like time for a new starter. While it could be electrical, in that the starter circuit is remaining engaged, more than likely it is mechanical. As the starter wears, you get play in the starter gear. Replacing the starter should take care of it. If you have recently had the starter off or replaced it, it could be misaligned, causing a similar problem.
Mar 27, 2010 | 2003 Oldsmobile Silhouette
F 150 starts and starter stays engaged unplug alternator starts ok but no charge
2 problems, first you have bad starter or starter relay for starter staying engaged, keep alt plugged in has nothing to do with starter staying engauged, to test starter relay, jump at relay bat + post with red/bk wire on solonoid, if cranks over without staying engaged, then not relay or starter but rather in your ign switch, ford had bad problems with ign switch some years ago doing that
Feb 05, 2010 | 2006 Chrysler PT Cruiser
Starter stays engaged after motor starts.
solenoid on starter is sticking and needs to be replaced or repaired
Oct 13, 2009 | 2002 Chevrolet Impala
you need to tell us the make model and year of the vehicle and the kind of remote starter u have installed on the vehicle
Oct 09, 2009 | AutoCommand Remote Car Starter Add-On
97 fatboy starter engages but will not stay engaged.
I would check the starter clutch its self first. It is a one way clutch so if you remove the starter and disassemble it to the starter clutch and hold the starter clutch in one hand and use your other hand to turn the starter clutch gear, it should only turn in one direction.
Mar 30, 2009 | Harley Davidson Harley-Davidson Motorcycle...
Lands Phones Logo
22 people viewed this question
Top Harley Davidson Lands Phones Experts
Tom Diffin
Sheldon Dedek
Steve F
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
