I have a 55" Panasonic flat screen that won't turn
  • Official Brand Answer
  • 350 Answers
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Posted on Oct 24, 2013
6ya staff
SOURCE:
Anonymous
SOURCE: MY PANASONIC FLAT SCREEN VOLUME AND TV CONTROL DOES NOT WORK!!
Try unplug the power cord while the tv is still on. plug it back after 5 mins. it should work.
Posted on Sep 08, 2009
Anonymous
  • 11 Answers
SOURCE: Panasonic flat panel just lost power while on,
Me the same some one please help!!
Posted on Mar 20, 2010
ronaldo_ross
Ronado Panaligan
  • 1056 Answers
SOURCE: My son dropped my 32'' inch LG lcd tv now it won't
It probably has a cracked circuit board. If you want to repair it on your own open it up and see if you can find where that cracked section is and see if you can resolder it back properly.
Posted on May 28, 2011
vinceisaac
francoise cleofas
  • 2432 Answers
SOURCE: My son is in Stanley
hi the problem with your tv is with in button key controller board, here are the ways on how are you going to fix the problem.
  • open the back cover of your tv with the use of philip screw driver to gain access the button controller.
  • remove the connector and then detached the controller board, spray the channel up/down button with a electronic contact cleaner to have good contact.
  • if the buttons are worn out you can replace only the buttons just buy at any electronics store, you can also buy or replace the whole button key controller if you want. there are sites in an internet which provide button key controller for tv like for example you can inquire here.
  • now after you replace with new button controller reinstall the connector fix it not to loose and then placed the back cover of the tv unit and screw it.
  • plug the power cord then turn on the unit. good luck i hope it will help you.
Posted on Jun 10, 2011
Testimonial: "Thank u so much. If this works it will save us so much money. I'm disabled and live on a very limited income. Thank u. Thank u. Thank u."
FaceTheFacts
Steve Burt
  • 245 Answers
SOURCE: tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
Posted on Jun 24, 2011
Lg 42ls575t won't go to "input" screen or "home" screen so cannot select HDMI channel. "Loading" message appears for 30s or so then disappears
solved.
1- turn off you router
2-go to settings
3-ok on the ? (support)
4-inatialisation of premium.
Problem solved
Apr 15, 2013 | Televison & Video
My Panasonic Viera Tc-p55gt31 has no picture and no sound
One of the circuit boards has a burnt connection. Look around each of the heat sinks to find the popped plastic circuit. You can also dismount the board and look on the bottom for a burnt mark. Check the number of blinks from the LED. That will tell you which board is bad.
Feb 10, 2013 | Panasonic " VIERA 55"" Class / Plasma /...
TC-32LX700 WON'T TURN ON
My Panasonic does this periodically. I have to unplug it for a moment and then plug it back in. Sometimes it will turn right on, sometimes I have to press the on/off button. I wish I knew the root cause.
Nov 10, 2012 | Panasonic TC-32LX700 Television
"LOC". As I turn the dial to the requested setting, all the times (15min. 55 min., etc.) are displayed, but as I go to push the 'start' button, the screen says, "LOC",...
Hi, "LOC" indicates that the control panel settings are locked. Press the SELECT and OPTION button simultaneously to toggle this 'feature' on or off. Hope this helps.
Regards,
Richard Roth
http://appliancecafe.com
Nov 07, 2012 | Frigidaire Electric Dryer
Panasonic tc-p60gt30 won't turn on. Something hit screen. Screen did not crack but now won't turn on
May have damaged the PDP (plasma display panel) inside---if the panel which is fragile shorted inside it will trigger shutdown.
Aug 28, 2012 | Panasonic 60 TCP60GT30 3D Plasma TV
Vizio M550NV 55 in HDTV LEDTV WON'T TURN ON
You have inadvertently deleted some operation system application files. The software may need re-installation. This is a case to be handled by a qualified service technician.
Jul 16, 2012 | Vizio M550NV 55 in LCD HDTV
Panasonic viera Plasma TV model TH-P42X10A The tv
The power supply board of the television is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
Aug 01, 2011 | Panasonic Televison & Video
Cannot remove the 'store' settings from 55 inch vizio bought at costco today When i push the "OK" button on the remote it 'thinks' that I'm pushing the 'menu' button and gives me the 'menu'...
Unplug the set for 20 minutes then plug it back in and turn it on. You should see a setting that says HOME____STORE on the screen. Make sure you high-lite HOME. Then continue on.
Dec 27, 2010 | Vizio XVT553SV 55 in. LCD TV
Flat scren wont turn on
Try a power drain:
1. Unplug the TV's power cable so that the TV is not grounded to the house.  Do not simply turn off a powerbar if one is in use. 2. Press and HOLD the TV's own power button for one minute to drain the internal capacitors. 3. Plug the TV back into a wall outlet versus a powerbar, if one is in use and see if this makes a difference.
If the TV does not turn on, are you able to see any indication from an internal LED light in the back of the TV?  If not, the problem is usually with the power supply. If you do see a LED light anywhere, then you know the TV is getting power but the TV's mainboard is at fault.  In either case service would be required if the power drain does not resolve this.
Mar 24, 2009 | Sony Televison & Video
Televison & Video Logo
273 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
