RCA 27V530T 27" TV Logo
A
Anonymous Posted on Sep 29, 2013
How do I undo the factory reset on my RCA 27V530T tv
3 Related Answers
Anonymous
  • 131 Answers
  • Posted on Apr 27, 2008
SOURCE: horizontal and vertical adjustments
sorry there is no adjustment for this .you probably have a bad component in tv
thanks Doctor video .
Anonymous
  • 3130 Answers
  • Posted on Jun 16, 2008
SOURCE: Locked RCA TV 27V530T
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it’s self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
  4. Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Anonymous
  • Posted on Jan 16, 2010
SOURCE: Parental Lock Code
If you forget your password you can reset it. Make sure the
TV is off. Simultaneously press and hold VOL< on the TV’s front
panel and CLEAR on the remote for approximately 5 seconds. Enter
a new password next time you access the PARENTAL CONTROL
menu.
Power cord
you would need a qualified tv personal to re- insert the power chord
Digital turner or not
CONVERTER BOXES are For those who use a antenna to receive a Free Signal Channels.So if you have Cable or Satellite this will NOT have any affect on what you are now receiving.
27V530T lines
Reset your TV, and then when it turns on, it will be all set. Not restart, RESET.
If this helps at all, please rate this a FixYa. - Evolution
RCA 32" SDTV
27V530t......my TV powers off and on all by itself and wont stay powered.Can you help ?
2answers
RCA 27V530T Powers up and plays perfect for about 5 min then shuts off
look for cold solder joints on primary side of power supply
1helpful
1helpful
27v530t
Two replace a verticale ic which is common for verticale problem.. It requires replacing a part not adjustment . I charge at my office is around 95,00 dollars to 120.00 dollars.
Thanks doctor video
Unusable Signal
I have exactly the same problem, with my RCA F27645. I can find no answers on the internet, so far.
I have 3 ideas.
1) The digital signal receiver must not be receiving the DVD signal properly.
2) Coaxial cable receiver (the little pin plug) problem
3) Digital TV (broadcasts) causing havoc on older TVs.
Horizontal and vertical adjustments
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
