These old types might be difficult to get; they are hardly available in the market. Nutritional Supplements Solutions
SOURCE: I need a manual for a Kitchenaid Food Processor Model #KFP600WH
The Kitchenaid website doesn't recognize the model number you gave. Could it possibly be KFP760? If so, then here's a link to the free downloadable manual.
http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/KFPW760OB_Use%20and%20Care.pdf
SOURCE: Kitchenaid Food Processor - Center Stem Support doesn't turn
Grease, it needs grease to lube it.
SOURCE: my kitchenaid processor is not working
The Kitchenaid food processors have a few safety features implimented. If the unit is not assembled properly, this may prevent the unit from turning on. I am thinking this is an issue of assembly because the light is on, so the unit is definitely getting power.
Proper assembly is below:
If it isn't all ready, please disassemble the entire unit. This means removing the blade and/or disc, blade, removing work bowl, work bowl lid, and blade.
Start by placing the work bowl onto the motor base. The work bowl handle should be facing at 9 o'clock, which is out to your left. Rotate the handle downward until it locks in at the 6 o'clock position, which will lock over the center of the button panel.
Repeat the process with the work bowl lid. The blade does not need to be present for the motor to engage, if this is an assembly issue.
SOURCE: Need owners manual for kitchenaid food processor model # KFP740CR
http://www.kitchenaid.com/flash.cmd?/#/page/home
this site should help you out.
one thing, you can chop onions without crying.
SOURCE: My kitchenaid food processor won't work
Does the actuator push down far enough to catch the button at the bottom? I repaired one simply by adding a vinyl screw cover to the top of the button so it was tall enough to be reached by the actuator.
Testimonial: "really helpful thanks"
