Question about Coleman Mach III Air Conditioner
Unit will come on and run for a minute and then will quite blowing
My 1980 450sl AC works good while in park, when I start driving it blows hot air could this be a vaccum problem?
Well, yes they did borrow the system from Chrysler and the main problem was with the main controller unit where you adjust the temp and has the controls. They were known to separate at the unit allowing vacuum to leak and to cause this problem as well. Typically when it is running, you should be able to put your fingers at the rear of the unit and find the vacuum leak that way.
Jun 26, 2017 | Chrysler Cars & Trucks
Tip
Freezer not working, things to check
The unit needs two fans running and good airflow, one fan outside cools the condensor coil and the other inside the unit blowing across the evaporator coil, warming it. The compressor must start up. The defrost timer stops everything and switches on a heating element to defrost the evaporator for several minutes. Please verify these conditions. The condensor coil may get clogged with dirt and lint, the evaporator may get clogged with ice build up, or the fan may quit working due to bad bearings, need for lubrication, or burn out. The defrost timer has an internal motor and contacts which may quit working, some have a way to manualy turn it to switch its mode in case it quits working.
on Feb 11, 2015 | Freezers
Why is my heil Air exchanger fan not blowing
Sounds like you may have a bade blower motor.
Aug 17, 2014 | Heating & Cooling
Craftsman 18.5 hp, 42"cut, riding lawn mower quits running after 10 minutes
ONE OF OR YOUR COIL PACK...(UNIT PLUG WIRE COMES FROM IS PROBABLY DEFECTIVE
Jul 29, 2012 | Craftsman Garden
LG LP0711WNR blows cold air for a few minutes, then starts blowing warm air. It will start blowing cold air again if I wait several minutes. Or if I turn it off and wait a few minutes it will blow c
I just experienced this problem myself. What helped me was cleaning out the lint trap. My guess is that the until sucks in air through there, then conditions it. Blows the cold air out the top, and hot air out the tube. When it can't suck a decent amount of air in, the condenser can only condense so much of that limited amount of air. When it runs out, the unit just runs the fan until enough air has been condensed.
My lint trap was filthy, hadnt Bern cleaned in years. Soon as I popped it off, the unit started belching out cold air nonstop. Clean your lint traps! Don't make my mistake!
Jul 09, 2012 | LG LP0711WNR Portable Air Conditioner
Tractor starts and runs for 2 minutes and quits. New spark plug didn't help. No spark after tractor quits running. It will restart in 10 minutes.
Sorry to stste the obvious, but it is going to be an ingnition unit breaking down, the only answer to this is to replace the unit, contact the engine manufacturers dealer with all the numbers from the engine housing, this should help to find the correct unit.
Jun 24, 2011 | John Deere Garden
Air not blowing from vents..or not cooling
It is quite possible the indoor coil is frozen up. This can be caused by dirty filter, dirty coil or low on freon. Turn ac to "off" and fan switch to "on" for 45 minutes. Then try again and see if air flow improves.
May 14, 2010 | Carrier 38CKC060 Air Conditioner
Fan quitting on unit
Maybe the room is dry enough so the humidity sensor is turning it off?
If not, maybe the thermisensor(fuse) on the fan motor is failing?
Jan 02, 2010 | Comfort-Aire BHD-501 Dehumidifier
Ac fan on, blowing air, but not cold
Check outside unit if unit and compressor are running feel the large line to see if it is cold. If compressor is running and line is not cold possible charge problems. You may have a capacitor problem outside. they go out quite often. You can change this yourself, Open up outside unit and the cap is the silver bullet with terminals out the top. Bad cap can cause compressor to not operate and also the fan. You need to clean the coil inside or at leat check the coil to see if it is clean. You can clean theis with a toilet brush do not go against the coil bit brush with the fins. You may need to call a service tech but try these options first. russ
Aug 15, 2009 | Heating & Cooling
I own an armstrong air unit after about 30 minutes the unit seems to get hot and the fan quits the compressor is still running I changed the motor on the fan and it still does the same thing I have also...
Chech the fans rotation , the fan is suppose to blow air out the top, also if you changed the fan out ,check for the blade on right, its suppose to scoop the air from the inside and blows it out the top,, also replace the capicator...sounds to me like the motors getting too hot and tripping on internal ly high temp. Hey, slow down "Big Money"! The problem is around the fan location! Thank-you-very-much!
Aug 27, 2008 | Heating & Cooling
Coleman Mach III Air Conditioner Logo
178 people viewed this question
Top Coleman Heating & Cooling Experts
Paul Carew
Marvin
Marvin
jdthefixer
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
