SOURCE: Static in playback of VCR on Panasonic DMR -EZ47V DVD/ VCR combo.
First make sure the cable on the back has the center pin and its in nice and tight.I would also try another VCR on the same line that way you can eliminate that first.Then if that doesn't show a problem it maybe a internal problem with a lose solder joint.Also I was wonder does the horizontal lines appear when you use a prerecorded tape.If it does you may need to clean your heads on the VCR.
