HP Compaq nc6400 Notebook Logo
Jon Sketchley Posted on Sep 29, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hard drive when setting up windows is not recognised
Dale Johnson
Level 2:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Expert 110 Answers
  • Posted on Sep 29, 2013
Dale Johnson
Expert
Level 2:
New Friend:
Greenhorn:
Answers
110
Questions
Helped
14816
Points
226
It may be a pin jumper setting or the drive may not be pushed onto the pins all the way, but remember hard drives do die from rough handling or just plain old normal use. did you go into setup and make sure it is recognized in there? if it aint there it just aint. good luck
Not use Touchpad Laptop cq40 to croll
Mabee the hard drive has failed . try entering bios and see if the hard drive is recognised .If not try turning the computer off unplug it then reconnect the drive data cable and power cable
then re- start the computer and see if it is recognised. some models of older hard drives needed a driver installed during set up -- you usually have to put the driver on a floppy disc and hit the f6 button when prompted by windows set up to install third party drivers . I hope this helps
Bottle jack leaks at release
I bought a yo phone an i need 2 get d settings for it
8 gb zune does not take a charge or turn on.
Apr 08, 2011 • zune.net
RESETING THE PHONE CODE
Vga is not working my mother board is a n1996
Edit my photo on facebook
4helpful
3answers
WINDOWS SET UP FAILS TO LOCATE THE HARD DRIVE ACESS SEEMS TO BE DENIED
Andrew.A
Windows 2000 advanced Server does not support Seagate 250 GB Hard Drive.
I am inclined to think that this would be a problem with the jumper settings limiting the size of the drive.
I can't offer anything more than that, sorry. Hope it will help a bit.
PC not recognising the slave drive
Assuming you set it as slave or cable select as required by the motherboard, you have to first get the bios to recognise it press F2 or Del on boot up to enter cmos and then there should be an option to auto detect drives, save settings for a re boot. When in windows, right click on my computer icon and select manage>disk management and then your drives will be listed, right click on the slave drive and select format or set as active and it will then show, but only 137GB may show depending on the bios version.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
