Question about Garden
Need operators manual for stihl chainsaw model ms 381
Posted by kathleen may venter on
Kelly Buxton
    Sergeant:
  • 322 Answers
Stihl doesn't make an MS381 but here is a link that should take you to their site to get manuals
http://www.stihlusa.com/manuals/instruction-manuals/#chain-saws
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Posted on Oct 01, 2013
5 Related Answers
dontbother10
dontbother10
  • 2220 Answers
SOURCE: Stihl ms 290 chainsaw. Clutch oil pump is this
The oil pump is behind the clutch drum. The drum is a left handed thread. HTH
Lou
Posted on Sep 09, 2009
Anonymous
  • 148 Answers
SOURCE: tunning specification for a stihl 028 chainsaw?
I'm not sure there are any "endorsed" tuning specs from Stihl as weather, temperature, fuel quality etc all contribute to engine performance.
Pictures of all types are all over the web.
As for the carb tuning procedure, maybe I can help?
Start with fresh fuel, all filters clean, and bar and chain installed. Also, fill the chain oil tank with bar/chain oil and VERIFY that the chain oiler works properly.
Initial fuel mixture settings (the H and L screws) should be 1.5 - 2 complete revolutions counter clockwise from lightly seated. Sight the carb's throttle plate and adjust idle screw counter clockwise until the plate stops moving.(Throttle closed completely.) Then go back clockwise 3 complete revolutions. This will produce an acceptable startup condition on a HEALTHY saw.
Clamp the bar in a STURDY bench vise and roll the chain with the shank of a screwdriver to verify it is clear. BE SAFE!
Choke the saw and pull the starter rope until the engine "burps".
NOTE: If no burp after 6 pulls, stop! Something is wrong.
After the burp, set choke to half and pull starter until it runs. The settings I gave should produce a slightly rich condition and a slightly high idle. (Chain will be in motion!)
Blip the throttle trigger and idle it down just enough to keep it running during the tune procedure.
Step 1) Using the "L" screw (closest to the engine), turn it clockwise until the engine smooths out or possibly increases RPM. Back it out slightly until the engine has a slight "LOPE" sound to it. (Like a drag car on nitro).
Step 2) Accelerate the engine to full throttle and go to the "H" screw (closest to the air filter) and slowly turn it clockwise and note the RPM increase. There will come a point when the saw will "Top-Out" and loose power. Not even enough power to turn an maintain empty chain's RPM! Go back counter clockwise to the edge of that point, and counter clockwise another fourth (1/4) revolution.
Step 3) Idle the saw back down. Again go to the "L" screw and repeat Step 1.
Step 4) Repeat Step 2.
Step 5) Idle the saw down until the chain stops moving completely. NOTE: Don't settle for a "crawling chain" condition. If the steps above are performed well and all else is healthy, you should be able to idle the engine down to a ridiculously low RPM and it will not shut off.
Hope this helps,
Dolf-
Posted on Oct 13, 2009
Beerm0nster
  • 82 Answers
SOURCE: i need a parts manual for a stihl 026 chainsaw
Parts list here http://bricomeca.free.fr/Stihl/stihl%20026%20IPL.pdf
if this helps please leave feedback
Posted on Feb 04, 2010
SOURCE: stihl 009 chainsaw
http://www.ultimatehandyman.co.uk/manuals/stihl/19.pdf
manual above it is all in there..
Posted on Mar 26, 2010
Anonymous
  • 14 Answers
SOURCE: Stihl MS 250 16"
take the bar off and give it a good clean, get compressed air and blow it into the oil tank, making a seal around it first
Posted on May 10, 2010
How do I find a parts manual for a Stihl MS290 ?
I really don't want to be "that guy", but people who aren't trained STIHL mechanics or at LEAST mechanically trained, shouldn't work on higher end saws like STIHL, because people with a little bit of experience can mess something up, then blame the machine because they mess something up and start trashing the brand when it's their fault for not knowing what they're doing.
Dec 18, 2016 | Stihl Garden
I need to replace the piston in my MS 441 Stihl chain saw.How do I remove the carburator
go google and type in ---workshop manual for stihl chainsaw model ms441--
download the pdf version
Nov 06, 2016 | Stihl Garden
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
https://www.youtube.com/watch?v=-xJAcXZqeog
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
https://www.youtube.com/watch?v=dZq7ZDBx4iA
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
www.stihlusa.com/WebContent/.../MS290_310_390_Manual.pdf
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
Is the LA adjuster for oiler to chain& what 1/4 turn per run to check ratio??
PDF]STIHL MS 261/261 C Chain Saw Instruction Manual ' STIHL ...
www.stihlusa.com/.../ms-261-261c-chain-saw-instruction-manual.pd...
Stihlde la rueda dentada usada y de otros ... this manual to operate your chain saw. ..... 1/4 turn). Misaligned, damaged or broken cap. N. If the cap does not drop fully .... adjust the chain while the engine is running! Warning! To reduce the risk of fire ...... bolts and screws except the carburetor adjustment screws after each use.
[PDF]STIHL MS 200 T Arborist Chain Saw Instruction Manual ...
Dec 15, 2015 | Stihl Garden
Google map philippines
Check the sealing O-ring between cap and tank if it looks suspect change it.
Jun 28, 2014 | Stihl Garden
Stihl ms 381, I have a MS 381 I got from a China
Typically, the clutch is activated by the engine speed.
If the chain is moving during idle, the idle speed may be the issue.
Lowering the idle speed may be the answer.
For dis-assembly look for a model specific exploded view of the assembly to see what other fasteners or means are needed to disassemble.
This illustration only shows the clip.
If after removing the clip, the clutch "Bell" does not come off, it may be held in place by the clutch pads, that may have seized. Carefully pry on the "bell" rotating it 180 degrees between attempts.
Not not use excessive force for fear of damaging the "bell" or other components.
Good Luck!
stihl-chain-saw-oil-pump-and-clutch-system-ms380-ms381--gdxvjlamvobgdwvowbkaqrcj-4-0.jpg
Oct 04, 2017 | Garden
Where do I find a operating manual for my STIHL 210 Chain Saw ?
Don't believe everything you read.
Your OM can be found here:
Stihl Product Instruction Manuals
http://www.stihlusa.com/information/info_product2.html
This was returned from my attempt:
http://www.stihlusa.com/stihl_ownersmanuals/MS210230250_Manual.pdf
IPLs (parts lists) are proprietary and not available to anyone not a Stihl dealer.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Mar 21, 2011 | Stihl MS 290 Chain Saw include 20" 50cm...
User manual required for Stihl Chainsaw model MS 260
You can go right to Stihls website, and print off a PDF copy.
www.stihl.com
Please let me know if you found it ok.
Feb 09, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Garden Logo
107 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
