All top loader washers have a lid switch so machine will stop when lid is raised,on the inside of the lid the is mounted a small plastic cover with a magnet inside which activates a switch just under the top of the machine if the magnet is gone thats your problem,if still there then switch is faulty
all top loader washers have a lid switch so machine will stop when lid is raised,on the inside of the lid the is mounted a small plastic cover with a magnet inside which activates a switch just under the top of the machine if the magnet is gone thats your problem,if still there then switch is faulty
SOURCE: I KEEP GETTING A dE
you will need to replace the door sensor, this error will appear until it has been replaced. it is inside the unit and pretty much hard to get to if your not familiar with workin on it. take it to an LG tech or some one whos familiar with it..........
good luck LG's are very sensitive.
[email protected] for more info.
SOURCE: I am getting error DE
HI there,
Well most of the times problem is in the door lock may be it's faulty. or it could be the door lack has failed/is failing or the control board, try closing the door properly and see if it works....... If further you have the same problem then you need to change the door lock (switch).
Good Luck
Thanks for using FixYa!!
SOURCE: my machine lg top loader
this means door error there is a magnet in the lid that falls of and this is how the computer knows the lid is shut lg dont sell the magnet you have to replace the whole lid sorry.
SOURCE: I have a LG Fuzzy logic for a year and a half now,
certain materials give off fluff and some others seem to attract it. you can try putting in similar materials together and avoid mixing turkish bath towels, blankets and jackets and such clothes having fluffy lining with normal clothes. Also try selecting higher water level (overriding the automatic selection) manually. Once when i had fluff on clothes, it turned out to be tissue paper from my child's jeans pockets. After cleaning the filter bag, run the machine empty at maximum water level every week. Hope one of these will help solve your problem.
SOURCE: What is the problem if
Pressure Switch faulty.
Replace with P/N: 6501EN1001A
Reply if you need directions for removal & installation.
Good Luck!
* If you found this solution helpfull, please rate with 4 thumbs up & a testimonial.
