Question about OKI C Office Equipment & Supplies
My Okidata C330dn has a "Service Call 991:Error" code. How do I resolve this without a service call?
Posted by Amy F on
  • Amy F Oct 01, 2013
    Follow-up info: This appears to be a problem with the cyan cartridge chip. The "1" at the end of the error code indicates cyan. I had just refilled the toner and put in a new chip. Putting the old chip back in changed the message back to "412: C toner empty". Putting the new chip back in brought back the "991" error. So I will be contacting the vendor of the refill kit.
    And a comment to the fixya AI gurus - none of the "suggested solutions" were for the correct model printer, and three of the four were of the "this problem is not easily fixed" unhelpful variety.
Artur Bieniek
Probably one of colour cartridges (usually not original from OKI) is updetting the printers logic Swap they around (even if you have to use old cartridges), find offending one and replace.
Simple.
Posted on Jul 15, 2014
1 Related Answer
Anonymous
SOURCE: Okidata C5150 Servicing
I just changed all my color cartridges but the color printing does not show the right color. Is there a way to calibrate the colors or check how each cartridge is working or not?
Posted on Sep 06, 2008
How can i clear printi queue
on the computer- go printers and devices , printer - printer queue or printer tasks
high light tasks not required and delete
Oct 23, 2016 | Office Equipment & Supplies
2 3 4 orange blinking lights/ automatic start up and forced shutdown/ optiplex 960
Log in to: http://www.dell.com/support/home/us/en/04/product-support/product/optiplex-960/diagnose and send this info to Dell. As I recall lights 2,3,4 are either memory or HDD failure.
Run Diagnostic Run Diagnostic Diagnostics can be run on supported Dell devices with a full version of Windows.
Already have an error code from running ePSA diagnostics?
Dell devices come with preboot diagnostics to capture error codes. If you have already run a preboot system assessment (ePSA), enter the error and validation codes with your Service Tag below and complete the steps to resolve your issue. Enhanced Preboot System Assessment Error Code (without 2000-prefix) * Validation Code * Service Tag * Part Serial # (optional) ; ;
Mar 28, 2015 | Computers & Internet
OKI C330dn Call Service fatal Error:980
That particular error indicates a fuser failure. Try turning off the printer and re-seating the fuser. If this does not clear the message then the fuser needs to be replaced. With such a low number of prints warranty should cover it.
Aug 29, 2014 | Oki Electric Industry C330dn Led Card...
Okidata printer c330dn copies have black smudged edge on the right
your drum cylinder (opc) or dev roller needs to be replaced
Aug 05, 2014 | OKI C Office Equipment & Supplies
Mb480 service reset
What kind of service is needed? Is there an error on the op panel?
Jul 08, 2014 | Oki Electric Industry Okidata MB 480 ...
Service Call 069: Error
My printer (Oki C330dn) experienced a hardware issue that placed it in a mode where it displays a 'Service Call 069: Error' on startup after the hardware problem was corrected. I used the following button combination at startup, which corrected my issue. Press and hold the BACK, DOWN ARROW, and OK buttons and power-on the unit. Continue to hold the buttons until you see RAM CHECK and some asterisks then release. This forces the unit to ignore all warnings and errors while placing it in an online mode. My printer came up to a ready state and worked normally. The next time I turned it on, it started up without any errors.
Aug 17, 2012 | Cisco Oki C330Dn Led Printer - Color -...
Hi error code: Call service 6020:0053103 Can't
according to my reading, a flashing power lights indicates a problem you can solve on your own. while a error like you typed would mean something that you cannot resolve without help. a problem like a bad controller, or a bad chip. maybe a eeprom issue.
If Call service appears, turn off the printer, disconnect the power cord, and contact your service technician
Some errors cause the alarm to sound. To stop the alarm, press [Cancel].
#### represents a mechanical error (#=0, 1, 2, ...). Call for service. The printer does not operate when this message is displayed. The total number of pages printed is also indicated, e.g. 0123456.
This woiuld mean you printed 53103 pages with that printer before the error occurred.
Good Luck
articale found here
http://www.manualowl.com/m/Kyocera/FS-4000DN/Manual/166388
Feb 14, 2011 | Kyocera FS-4000DN Laser Printer
Okidata Microline 30 Turbo dot matrix
The problem your having is a spacer motor. It's located under the carriage that holds the ribbon/printhead. The part number is 56513701. Available at Seattle Platen - Dale 1800-221-2388.
Here's a free copy of the Okidata 320T service manual that will walk you through testing and verfying before ordering the replacement part.
If this helped you, please hit me up with a FIXYA. Thanks.
http://www.feedroller.com/Store/Service%20Manual/SER320T.PDF
Aug 30, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
583 people viewed this question
Top OKI Office Equipment & Supplies Experts
Alvin Barnabas
Alvin Barnabas
Timothy Van Der...
Mike
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
