Question about Oster 12-Bottle Wine Cellar - Black
Power is to unit, but cannot get the temperature to less than 70
Breezaire WKL 1060. System was working but had iced up. Then followed instructions to clean up and restarted. It runs for a short period of time then shuts off with an E1 error code.
ON A WKL 1060 AND FOR THAT MATTER ON ALL WKL UNITS THE E1 CODE IS NOT AN ERROR CODE ITS A FEATURE.
ON INITIAL START UP OR AFTER UNPLUGGING THE UNIT FOR MORE THAN 10 MINUTES (RESETING THE BOARD) THE UNIT WILL RUN FOR 30 MINUTES AND THEN IT WILL CHECK TEMPERATURE INSIDE THE WINE ROOM, IF THE TEMPERATURE IS 70 DEGREES OR ABOVE IT WILL DISPLAY E1 AND SHUT OFF THE UNIT. YOU WILL HAVE TO RESET THE UNIT BY UNPLUGGING IT FOR NO LESS THAN 10 MINUTES TO RESTART THE UNIT, IT WILL RUN FOR ANOTHER CYCLE OF 30 MINUTES AND IT WILL RE CHECK TEMPERATURE AGAIN, IT HAS TO READ 69 OR LOWER FOR THE UNNIT TO RUN NON STOP TILL IT MEETS THE SET COOL POINT OF 55 DEGREES.
Jul 21, 2018 | Breezaire Refrigerators
How to solve error code E000000 - 0001
The temperature of the fixing assembly is abnormally high.
While startup control is under way, the reading of the main thermistor is less than 30 deg C continuously for 200 msec or more 1 sec after the start of power supply. While startup control is under way, the reading of the main thermistor is less than 70 deg C continuously for 200 msec or more 2 sec after the start of power supply. While startup control is under way, the reading of the main thermistor is less than 120 deg C continuously for 200 msec 6 sec after the start of power supply. The startup control does not end 30 sec after the start of power supply.
Nov 21, 2014 | Canon CANNON IR 3530 COPIER FOR 220 VOLTS...
My panasonic air conditioner does not turn off when cooling
At what temperature is the thermostat?
The temperature should never be lower than 70?F (21?C) for the unit to operate properly. If your temperature setting is above 70?F, then your unit might have a problem with the temperature sensor that controls the "on/off" cycle on your unit. For that you will need a professional certified HVAC tech to inspect it.
Most people think that lowering the temperature to the minimum will cool the room faster, but that is not the case. Since HVAC units move the air at a specific rate, it can only transfer the temperature, thus cooling/heating the air, within those parameters. That's what the calculation for the BTU is for. Normally cooling/heating the room to the desired temperature should take about 1 hour, but some new inverter units can do it in only 30 minutes or so. Lowering the temperature constantly or even keeping it at the lowest setting may cause premature failure of the unit.
Aug 04, 2014 | Panasonic 36PEF1U6 31,200 BTU Single Zone...
MITA TA180 ERROR MESSAGE C6000
Fuser heater break
Fuser thermistor 1 detected less than
70°C/158°F for 10 s during warm-up and
ready in.
During warm-up, the temperature at the
fuser unit thermistor 1 does not rise by
1°C/1.8°F continuously for 5 s.
Fuser thermistor 2 detected less than
40°C/104°F for 10 s during warm-up and
ready in.
fuser unit thermistor 2 does not rise by
Defective fuser
heater 1 or 2.
Replace the fuser heater 1 or 2.
Installation defectiveness
on fuser
thermistor 1 or 2.
Check the mounting state of the fuser thermistor
1. If any problem is found, repair it.
Defective fuser
thermostat.
Replace the fuser thermostat.
Defective PWB. Replace the power source PWB or engine
PWB and check for correct operation
Jan 08, 2014 | Kyocera Mita KM-1815 All-In-One Laser...
Canon copier 3380i copier with error code E000-003-0001
thi is the problem:
Error in the low temperature of the fixing unit
Detects the temperature detected by the sub thermistor is abnormally low (below 70 deg C) for 1 sec continuously while adjusting print temperature
and the solution is :
Check on connection of the sub thermistor/thermo switch, Replace the fixing unit, Check on a break in the heater, Replace the cover switch, Replace the main power supply PCB, Replace the DC controller PCB To recover from the error: In service mode COPIER>FUNCTION>CLEAR >ERR
Dec 03, 2013 | Canon Office Equipment & Supplies
I followed the instructions to a T. I turned my iHeater on using the--O switch located on the back. I adjusted the desired room temperature to 74 degrees. I adjusted the room size to Large. The iHeater...
I would read the customer reviews on this product , looks like nearly 70% of consumers are less than happy with this unit.
1500 watts is the units peak output, and drops to around 600 as it warms up. My hair blower puts out more power.
1500 watts is LESS than the output of a small element on your stove top. The real measure of heat is not watts, its BTUs and btus from gas are much cheaper than they are from electricity.
Nov 12, 2013 | IHeater 1500 Advanced Infrared Heater...
Wont run. It blinks
YOUR UNIT WKL 4000 CONTROL BOARD HAS THE FOLLOWING FEATURE ON START UP UNIT WILL RUN FOR 30 MINUTES IF IT DOENST BRING THE TEMPERATURE IN THE CELLAR BELOW 70DEGREES IN THAT TIME IT WILL SHUT OFF AND DISPLAY E1, YOU NEED TO UNPLUG UNIT FOR 15 MINUTES(NO LESS THAN THAT) AND THEN PLUG IN AGAIN IT WILL RUN AGAIN FOR ANOTHER 30 MINUTES ABD IF IT DOESNT BRING THE TEMPERATURE BELOW 70 IT WILL SHUT OFF AGAIN.YOU WILL HAVE TO REPEAT THIS CYCLE TILL IT GOES BELOW 70DEGREES (MOST CUSTOMERS WILL HAVE TO DO THIS CYCLE TWICE).ONCE THE UNIT BRINGS THE TEMPERATURE BELOW 70 IT WILL RUN NON STOP TILL IT MEET THE SET COOL POINT.IF YOU REPEAT THIS STEP SEVERAL TIMES AND THE UNIT NEVER BRING THE TEMP BELOW 70 DEGREES THERE HAS TO BE SOMETHING ELSE GOING ON, LIKE A REFRIGERANT LEAK.CHECK THIS LINK FOR THE INSTRUCTIONS THAT EXPLAIN THE FEATURE I TALKED ABOUT AND OTHERS ON THE CONTROL LER OF YOUR UNIT(SENTRY III)http://www.breezaire.com/downloads/sentrymanual.PDF
Sep 15, 2012 | Breezaire WKL 4000 Wine Cooler
Air conditioner
Maybe you set the tempture to 70 and when the unit is runnung it sinces the room tempture.
Jun 09, 2008 | Fedders A6P09S2A Air Conditioner
Default temperature settings
if it is anything like a monitor - look on the right side bottom for a slider - reset temperature adjust. just move the slider to a lower temperature. if you have a power outage, the display starts to flash 88:88
Dec 15, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Can Movincool classic plus 26 AC set the air temperature at below 70 degree F?
aircons normally pull down to approx. 17 degree celcius.and heats to approx 30 degree celcius.  most of the time you need to simply clean the condenser properly and to make sure fans are in good order.
Oct 16, 2007 | Movincool Classic Plus 26 Air Conditioner
Oster 12-Bottle Wine Cellar - Black Logo
55 people viewed this question
Top Oster Furniture Experts
Tom Chichester
ray gallant
Are you an Oster Furniture Expert? Answer questions, earn points and help others
