Question about Faberware FSW343 Electric Wok
Recoating a wok - Faberware FSW343 Electric Wok
Orange peel pivot. When I spray polyurethane on wood
you will get peel if you use different brands or if you do not wait long enough to recoat. you have to to recoat within one hour if not then usaully 48 hrs. Hope this helps mike
Nov 28, 2014 | Cars & Trucks
Recoat a pan
Many grocery store department bakeries send their pans or trays out to get re-coated on a regular basis. Perhaps look up a bakery in your area
Oct 16, 2013 | Kitchen Appliances - Others
I heard that you should season your wok before you use it for the first time. How do you do that?
1. Wash your new wok with hot water and liquid detergent.
2. Rinse and dry thoroughly.
3. Now place on the heat and keep tilting the wok until it has all turned a blueish-yellow.
4. Add a thin film of oil to cover the entire inside of the wok and use a paper towel to make sure the whole wok is covered with a layer of oil.
5. now put the wok back on a medium - low heat for about 10 minutes.
6. wipe the oil off with another paper towel. Don't be alarmed that you will see black on the towel.
7. Repeat the steps above until no more black comes off the wok.
Feb 18, 2013 | Home
I am really getting into wok cooking but have you got any tips for me?
Wok cooking is a really healthy and tasty way to cook but you have to know what you're doing otherwise it could all burn and stick. Take a look at this article that gives 10 tips to better wok cooking.
http://www.tigersandstrawberries.com/2006/01/16/stir-fry-technique-ten-steps-to-better-wok-cookery/
Feb 18, 2013 | Home
We left our telescope out on a covered deck. Now the mirror is badly pitted. can you grind it? or does it need replaced? (deep space hunter 10 ")
The mirror must be recoated -- the pitting is in the coating NOT in the glass--Google mirror recoating.
Here is one- http://www.opticwavelabs.com/
Feb 24, 2011 | Hardin Optical Deep Space Hunter 10...
Coating on heating plate peeling
only if you return it to the factory for recoating,but it is still safe to use.but it you have warranty on it still then return it to the store from where you bought it.good luck
Feb 27, 2010 | Kitchen Appliances - Others
Recoating my george foreman grill
The closest thing to what you are looking for is Secoa Technology - Dalton, GA Phone: 706-272-0133 Fax: 706-272-0135 You may need to call and see if they do recoating
Jun 03, 2009 | George Foreman GR30 Indoor Grill
Recoating the non stick surfaces of cook pots
yes there is it depends on your location, pls visit this site for info
www.thomasnet.com
cheers
Sep 13, 2008 | Faberware FSW343 Electric Wok
Electric frypan
you can make or try to send this to a recoating company
www.thomasnet.com
for a fresh coating
cheers
Aug 28, 2008 | Rival Kitchen Appliances - Others
Faberware FSW343 Electric Wok Logo
Top Faberware Kitchen Appliances - Others Experts
Dennis
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Faberware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
