Problem ide
Hi gustabir,
try this first. (If I am understanding you correctly).
Power on the PC, press the Delete key every two seconds untill the boot menu loads. Go to the title, Boot. Set you're boot device's in the correct order. They should be listed as follows.
1st Boot device Floppy drive. (If a floppy drive is connected).
2nd Boot device CD-ROM/DVD drive.
3rd Boot device Hard drive.
(If you're CD-ROM drive is not listed in the bios main menu, than you're CD-ROM drive is not connected correctly). Please check the CD-ROM data cable is firmly & correctly connected), also check the power cable is firmly connected). If you are using more than one CD/DVD-ROM drive on the same data cable, check that you are listing the correct CD/DVD drive in the boot order. To change the drive's order while in the Boot menu, see page 34 in you're manual.
If the above does not address you're problem, please describe the issue/problem again.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
