SOURCE: The oven of GE Profile range simply stopped igniting
If it is a ge it would have a glow bar ignitor, either a flat rectangle shaped or a round ignitor. That is want the problem is 95% of the time. It is pretty easy to do. The floor of the stove will come right out and it probably has two screws in the back corners you can see. Remove them and the floor will lift out and you can see the burner and the ignitor.
SOURCE: GE Gas Range/oven Model JGBS16 The glow coil in
could be a bad thermostat but it sounds most likely like a loose wire connection somewhere. if the coil comes on and doesnt quite glow as bright as it should, the glow coil needs replacing.
