At some point late in the wash cycle our 12-year old dishwasher makes a loud sound like a sports car revving up and needing to shift gears. This happens for about 30 seconds then stops. I think it happens twice during the cycle. Otherwise, it does seem to clean the dishes and there's no water left in tub at end. What should we do?
SOURCE: Dishwasher Making Loud High Pitched Noise.
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
SOURCE: Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
SOURCE: We have the Whirlpool Gold quiet partner III
Make sure your water is hot, at least 120deg f. Also, use least amount of soap you can get away with. Usually around 2 tablespoons for soft water. Use powdered soap not gel. Gel leaves a tiny residue each load and will clog up plumbing in dw after 4,5,or 6 years. Rinse agent such as Jet Dry is highly recommended.
Try the "Tang" trick. Orange Tang drink mix is mildly acidic. With an empty dishwasher, start and fill, then normal drain. On second fill, add a full jar of Tang then let the dishwasher run for a few minutes. Crack the door to stop the dishwasher and let it sit for several hours or overnight. Then close the door, push start and let the dw run through the remaining cycle. This will sometimes clean out the crud in the water lines.
Hope this helps! Ken
SOURCE: My 6 year old Whirlpool dishwasher is loud
This is a bad wash pump. Looking at about $175 for just the sump assembly. You could do it yourself, but unit would need to be uninstalled.
SOURCE: Whirlpool Gold quiet partner III, leaves dirty, greasy dishes
You need to clean out the trap in the bottom. It's a little involved to gain acess. You need to remove the bottom dish tray and set it aside. Then use a pair of pliars to hold the nut on the bottom spray arm and unscrew the arm from the nut. When you do it right, the spray arm will come off. Then you need to unscrew the two #2 phillips screws that hold the white water passage in the back and top. You can then turn it to the right and it will come out when you line up the 3 tabs. Then there are 4 Torx T20 screws that hold the screen on. Remove the screws and the screen. You should find all kinds of gunk, food, and who knows what else inside. You're not done yet, remove yet another T20 screw to acess the food grinder way at the bottom. You'll have to clean all the gunk out of there and make sure the screen and grinder aren't broken. Reassemble, and try doing another load, it should work much better. I found small chicken bones, wrappers, even a toothpick in mine.
