This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
SOURCE: Smeg oven diplaying an "A" in display
Alright - I am the person who left the message before. I left the oven on for a while with the A showing and the time started ticking away. I then pushed the end of cooking time button and then the button that switches the oven back to manual. Hope this helps you. Good luck.
SOURCE: smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
SOURCE: Smeg oven door off hinges
Try www.smegtech.com/site/smeg/pdf_libretti/914772524-GB.pdf section8
SOURCE: Smeg Oven
Their will be two elements in the oven a bottom element and a fan element, sounds like the latter has blown!
Testimonial: "Thanks, that helps. Will it be easy to fix? can I do it myself? "
SOURCE: The house I've just bought
Most of these ovens have two fans. A fan forced fan in the oven and a cavity extractor fan inside the cavity of the unit between the outer skin and the oven wall. The cavity fan blows hot cavity air out the front of the unit so it remains cool. If the orange indicator light is coming on this would normally be the oven element thermostat. Leave it on and see if it gets hot. If the light goes off when you select the function switch it means you are turning it off the oven function. Your interior oven light may be blown.
Hope this helps.
