Question about Adaptec Computers & Internet
Adaptec 2610sa controller kernel panic error 63
5 Related Answers
Anonymous
  • 82 Answers
SOURCE: kernel panic
upgrade the os
Posted on Oct 09, 2007
Anonymous
  • 30 Answers
SOURCE: MacBook Kernel Panic
To fix this problem, download and install Mac OS X 10.4.8 from - www.apple.com/support/downloads.
This should solve your problem.
Let me know how it went.
Posted on Aug 25, 2008
Anonymous
  • 195 Answers
Yes, your hard drive is fine from the stand point that there are no surface damage or bad clusters. What ever system you loaded on the hard drive has to be reinstalled. Good Luck.
Posted on Oct 28, 2008
Anonymous
SOURCE: Error 1604 and Kernel Panic
When this happened to me yesterday I tried all of the suggestions and more - many similar suggestions to do with itunes reinstalls, usb ports, the sim card and scripting (including on the Apple forums and support pages). None of it worked.
My issue was that the 'preparing to restore' phase of restoration became looped and eventually it crashed citing error 1604. However, there was a solution at: http://daggle.com/iphone-upgrade-fail-701 which did work for me.
For convenience:
1. Start the restore process (whatever way you can).
2. When it seems to be stuck in the loop (and possibly your iPhone just shows a blank screen) use CTRL+ALT+DEL and end task to kill the iTunes application.
3. Restart the restore process.
Posted on Jun 23, 2009
Macs R We
Macs R We
  • 481 Answers
SOURCE: i mac g4 kernel panic cant boot from CD to format
This message indicates that the CD you are attempting to boot from is a release of the Mac OS which is incompatible with this model of Macintosh. I would recommend a retail disk of Tiger or Panther for this vintage Mac.
Posted on Jun 18, 2010
LG K5 phone DemiGod Kernel Crash Handler Kernel Panic
This thread should help you ...
https://forum.xda-developers.com/lg-g3/help/demigod-crash-handler-kernel-crash-t3137380
Apr 02, 2018 | LG Computers & Internet
Resolve Error Code: C7 on SuperMicro Server
First check the OS compatibility for you motherboard here:
http://www.supermicro.com/support/faqs/os.cfm
Then, if compatible, check the IDE/SATA setting. Change the hard drive controller settings from IDE to AHCI or vice versa to see if the OS kernel panics on boot. If that does not work, please reply with your OS version and motherboard model.
Apr 12, 2012 | SuperMicro Computers & Internet
Mac laptop screen froze with message stating must turn off laptop
font.f1 { font: 12px Helvetica; } Thanks for asking your question with Fixya Support. I will be glad to assist you.
What you are experiencing is what is called a Kernel Panic.
A Kernel Panic, is a internal fatal error, detected by your system from which it
cannot recover from safely. Such an error can be the result of a software
function or operation failing to execute as it normally does, or halting without
warning, or even a hardware component, suddenly ceasing to operating
or simply shutting down. In either scenario, the system will display the frozen
black and white screen with the languages text listed.
Normally a simple reboot of your Macbook Pro will resolve the issue, but in some cases it can take a specific procedure to correct and prevent a kernel panic from occurring again.
So here are a few procedures you can use to resolve and prevent further kernel panics:
• First, hold in your power button for approximately 10 seconds to do a hard shutdown, if your Macbook Pro is still turned on.
• Once your Mac is shutdown, you will need to perform what is called a PRAM reset (Parameter RAM)
• Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously .
• Turn on the Macbook Pro.
• Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
• Now, hold the keys down until the computer restarts and you hear the start up sound for the third time.
• Release the keys and allow the Macbook Pro to start up.
If your Macbook Pro starts up normally and does not go into another kernel panic, then you should be able to resume normal session activity on your Macbook Pro.
However, should the kernel panic return, then you can use an SMC Reset to correct the kernel panic:
-SMC RESET-
The System Management Controller is an integrated circuit (computer chip) that is usually on the logic board of your Mac portable.
It is responsible for power management of the computer. It controls back-lighting, hard disk spin down, sleep and wake, some charging aspects, trackpad control, and some input/output as it relates to the computer sleeping.
Shut down the computer.
• Disconnect the MagSafe power adapter from the computer, if it's connected.
• Remove the battery.
• Press and hold the power button for 5 seconds.
• Release the power button.
• Reconnect the battery and MagSafe power adapter.
• Press the power button to turn on the computer.
Once again, when you are back up to your main desktop, resume your normal session activity.
At this point there should be no further issue a the kernel panic rearing its ugly head once again.
If it does, then you will need to take more intensive steps such as inserting your Mac OS X installation disc and booting up to that disc and running Mac OS X's Disk Utility, to repair the hard drive and permissions of the Mac OS X system you are using.
I will leave you with that procedure, in the event you need to run Disk Utility:
Insert your Mac OS X Startup disk
•Reboot your Mac
•At the Apple Chime, press the C key and hold it until you see a White screen, gray Apple and eventually a Spinning gear.
• Release the C key only after you see the Spinning gear.
•Mac will boot from the start up disk to the Installer environment
• From the Installer Menu bar, click Utilities > Disk Utility and open up Disk Utility application.
• Click on on the hard drive at the top of the window in the left sidebar and
• Select "Repair Disk"
**Let Disk Utilities run this repair the disk until completion
• At the end of this process, reboot your Macbook Pro
Return back to you main desktop and again, resume your normal session activities.
Any more kernel panics after this, you may want to consider taking your Macbook Pro in for service at your local Apple retail store Genius Bar or local Apple authorized service provide in your area.
I hope this information proves helpful for you.
Regards,
-Mactechtrainer
Mar 30, 2011 | Apple Mac Book Pro 15.4" 2.53 Core2Duo 4GB...
Hi. We have a ML110 server with RAID 5 (4x250gb HD SATA) in a Adaptec 2610SA. The RAID has 2 Arrays (#00 Operating System and #01 Data). We have tried to replace a failed HD and since then the Windows...
Did you make sure that your hard drive has been made into a "dynamic volume" instead to the usual "simple volume"? It has to be "dynamic" before your can put it into a RAID configuration. You will have to use your RAID Controller to create a dynamic volume or to make the hard drive part of a dynamic volume.
Aug 04, 2010 | Adaptec 2610SA (0H2052) Serial ATA...
Apple mac g4 laptop wont come on
Kernel panics are not what you have, you have a flashing question mark, it indicates there is a problem with either the hard drive or the operating system on the hard drive.
Kernel panics are different, the unit tries to start and then the unit crashes with a "kernel panic"
Feb 19, 2009 | Apple PowerBook G4 Mac Notebook
Aug 14, 2008 | Apple MacBook Mac Notebook
Kernel panic
Jul 08, 2008 | HP Compaq dc7600 PC Desktop
Kernel panic
upgrade the os
Oct 04, 2007 | Computers & Internet
Computers & Internet Logo
81 people viewed this question
Top Adaptec Computers & Internet Experts
John Dio
Level 1 Expert
Robert Graf
efs_perpends
efs_perpends
Are you an Adaptec Computer and Internet Expert? Answer questions, earn points and help others
