100% is the same thing as 1, so .25 / 100% is the same as .25 / 1, which is 0.25 as the calculator shows. Why do you think it should be 25 and not 0.25?
Testimonial: "ok maybe that was a bad example but my point is it does nothing when i type the % in ... nothing at all it just gives me the answer to what ever is in front of the % ."
it never did that before it only started recently in accounts clas
What happens when you press 2 5 % =? Do you get 0.25?
i get 25
SOURCE: problems with fractions on the Casio fx-115es
To convert fractions to decimals or decimals to fractions, you use the [S<->D] key. Each time you press the key the result is displayed in the other format.
Alternatively, If you multiply or divide two integer numbers put a decimal mark at the end of one of the numbers (any one). The result will be displayed in decimal format.
Hope it helps.
SOURCE: Hi, I have a Casio calculator fx-991MS giving me wrong answers!
I am only looking for a plausible cause of the error, because I do not believe your calculator can make such a mistake. I think you accidentally activated the Exponential display format and did not pay attention to the small, raised -03 that came at the end of the number displayed. It is a common mistake for those not very familiar with Scientific or exponential notation.
Let us try to reset your calculator to the normal (floating point) format.
Press the [MODE] key a number of times until you reach a screen that has FIX, SCI, NORM and under each one a number (FIX 1, SCI 2), Norm 3). To have the number of decimal place you gave in your result (4 decimal digits), you press 1 to select Fix then 4.
Be aware that scientific calculators usually stop displaying results in floating point format ( 0.0000045 ) if the number is smaller then 0.001. So basically, 0.00099 will be displayed as 9.90-04, -04 being raised above the level, and in smaller size.
Hope it helps.
Testimonial: "Thanks so much, its working now:) I thought I was going to have to buy a new calculator!"
SOURCE: PLEASE HOW DO I CHANGE MY CASIO FX-82MS
Use the FIX display format and set the number of decimal digits to be displayed to be 2 o 3 or more depending on your needs. Instructions are on screen capture below. Hope it helps.
SOURCE: how can i change this
To convert a single value, press the S<>D key. To have all answers come out in decimals, press 2nd MODE 2 to select LineIO.
SOURCE: my casio fx82 au plus calculator is answering me
Loook for a key marked F<>D and press it to toggle between fraction and decimal displays.
if i press 25% i get 25
25%= gives you 25? Note the "=" after the "%".
i did 25%= gives me 25
