Question about Miele CVA610
Keeps saying refill beans , I have- its full
Doesnt sound like coffee being ground but maybe its jammed? Keeps alerting me to fill beans.... But the reseptacle is full. I assume it must be jammed..... How do I fix it?
Posted by william on
fkuk
  • 311 Answers
The top of the grinder may need cleaning This user manual explains everything http://www.cagrimmett.com/justanswer/CVA610.pdf
Posted on Oct 02, 2013
Grinder spins. Hopper is full of beans. Why is no ground coffee dispensed?
You will probably find that the grinder is bunged up with grounds. This can happen if there is a bit too much steam inside the housings. The grounds bind together and will not drop with gravity. Pull the grinder apart, clean it out then run it with the top housing off and see if you can observe any leaks/steam. There will be some steam, you are looking for excessive steam.
Sep 13, 2015 | Miele CM 5200 Espresso Machine Black
Why won't it brew?
Think the grinding mechanism is jammed with something. Disassemble unit and look for same.
Sep 03, 2017 | Saeco Vienna Plus Black Super-Automatic
HOW DO I CHANGE THE GRINDING MECHANISM ON MY SPIDEM TREVI EXCLUSSIVE ESPRESSO MACHINE. I HEAR THE MACHINE GRINDING BUT IT'S REALLY NOT DOING ANYTHING. ANY SUGGESTIONS
When the grinder spins free and fast it only means that fresh beans are not feeding into the burrs. This happens when:
1- Grind setting is too fine and beans cannot enter the grinder mechanism.
2- Use of oily dark roast beans can clog the ground coffee chamber and preven the fresh beans entering the grinder.
3- The ground coffee chamber outlet is clogged due to oily beans or too fine coffee setting.
When you cleaned the grinder you may not have cleaned the coffee outlet to the doser on the left. You can clean the outlet to open the passage of coffee grounds to collect in the dosing device..
After cleaning the outlet, you should next make sure that coffee grounds are not packed in the doser. The doser is inside the door right above the brew group.
To access the doser:
1- Remove water tank.
2- Remove the brew group.
3- Lay the machine on its back for full view of the doser.
4- Pull the doser door open (it is like an Attic door.
5- Keep the doser door open and clean the inside with a brush. The outlet from the grinder is on the right side with a wire wiper cleaner that moves across the grinder outlet fills from the grinder. This opening.
Use a brush to clean the doser.
On the left of the doser space there is a plastic flap that is pushed to the left when coffee grounds fill the doser.
At certain distance push back (1/4") the notch on top of the flap pushes the doser micro switch pin to stop the grinder. Push the flap gently to the left to make sure that it is moving well. With each push back of the flap, one can hear the feeble click sound from the micro switch.
When the above cleaning is done, try the grinding.
If the conical burrs have not been replaced for over 2500 grinds, it is time to do so.
The above grinder and grinder doser cleaning instructions are available as download files on the following page link:
One can find many useful maintenance guides on one page.
Good luck.
http://www.partsguru.com/MaintenanceofEspressomachines.htm
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Feb 10, 2015 | Spidem Coffee Makers & Espresso Machines
Why Coffee Machine keeps saying 'fill coffee beans' ?
Unplug it to disconnect the electrical power.
Reconnect it.
Look for a "sensor" that determines when the hopper is filled -- is that "gummed-up" or "jammed" ?
Jun 12, 2014 | Saeco Coffee Makers & Espresso Machines
The readout keeps saying "Fill
u need the grinder stripped ..might need spares ? bsc appliances 07779933829 we carry out repair service via post anywere..
Dec 14, 2010 | DeLonghi EAM3400 Espresso Machine
No coffee coming out
sounds like you have a bean jam post your model i will send you the guide on how to fix this it is too long to type here
Aug 17, 2008 | Miele CVA615 Espresso Machine
Miele CVA610 Logo
314 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Vincent G
Vincent G
Andrew Taylor
Andrew Taylor
Dennis
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
