Question about Harman Kardon SoundSticks II Computer Speakers
The left speaker on my Harman Kardon Soundsticks II has stopped working? The right speaker and the sub woofer are fine. Everything's plugged in and nothing's damaged. I have also tried the speakers plugging them into my phone and still the left speaker has no sound. Please help. Many thanks. Michael
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 25 Answers
Something must be damaged or in need of cleaning.
Posted on Sep 30, 2013
Open SKy
Carlos L. Burgos
  • 620 Answers
SOURCE: Harman Kardon Soundsticks II left speaker
Hi, Kazim
Firts things First:
1) check connector for 2 way sound. you can use a headphone for this.
2) you also buy Ipod dock sound speakers, there is Ihome speakers, great ones, for less than 25.00 dollars.
3) you have to see balance on those speakers.
good luck
Posted on Jan 23, 2008
Need to replace th 5 pin DIN plug on harmon kardon sounds stick 2- dog chewed thru it and the plug is gone!
If the mentioned cable is the one that is connected to the motherboard of the sub woofer and has two connectors for the speakers on the other side - please contact the Harman/Kardon support of your country, as they may be able to replace this part (actually this is a very rare part) it also may occur that the company will not be able to replace the part with a genuine one, but with a modified one. You can also try to contact some companies that would be able to replace this cable with a custom-made one.
Dec 25, 2013 | Harman Kardon SoundSticks II Computer...
I have a active sub woofer (akari bazooka) but the only connections available are the speaker connections. The front of the sub woofer has volume adjustment. How can I connect this sub woofer to my Harman...
hi,
You can't connect the pre out of your AVR to this sub woofer. Do one thing connect the frond left/ right channel speaker "B" out of harman kardon to the sub woofers left right speaker in put. you can connect the speaker out "A" to your normal left right speakers. Remember to switch Speaker "A" and "B" in ON position in your AVR. Also do one thing go to the speaker setup of AVR and switch OFF (slelect NONE) the sub woofer.This will disconnect the sub woofer pre our and the sub frequency will mix with frond left right channels.
ok
May 20, 2011 | Harman Kardon AVR 135 Receiver
My Harman Kardon Soundsticks 2 stopped working. They are plugged in, I restarted, the loudspeakers are at 100 and NOT muted, and still I can hear nothing. What do I need to do to resolve this please?
Ok, let's see if we can work this out. You say the speakers are at 100. Where are you seeing this 100? You say the speakers are NOT muted. Where are they NOT muted?
Is the light on in the sub-woofer? Is the volume turned up on the right hand speaker?
Plwase answere these and then we'll see what to do next.
Feb 06, 2011 | Harman Kardon SoundSticks II Computer...
Harmon Kardon SoundSticks II sub-woofer cleaning
These "proposed solutions" obviously have absolutely NO relation to the problem stated. Which by the way is far too typical of this site. :(
Apr 29, 2010 | Harman Kardon iSub Computer Speakers
My harman kardon soundsticks base light flickers, no sound
Ok this needs careful observation to determine this type of problem
Please unplug these speakers and plug it into an mp3 player and write back to me if the speakers work ok? I'll tell you more from there
Mar 15, 2010 | Harman Kardon SoundSticks II Computer...
Soundsticks I dead
hi , i have the same problem with soundsticks II, they just won´t work anymore,,,,the light is still on in the sub but there is no sound coming out of the speakers.....it happend after i moved my computer from one room to another.....
Aug 26, 2008 | Harman Kardon SoundSticks II Computer...
Sub woofer full of moths...How do I dismantle it without damaging anything!
un do screws and then un clib it apart clean it vacum it maby add moth ball when done lol thx nick
Mar 13, 2008 | Harman Kardon SoundSticks II Computer...
Harmon Kardon Sound Sticks
Hello there
First things First:
1) check cables, and the input cable to your PC.
2) Check for right voltage, may be somethings is chargind a lot**
3) Power regulator on the Speakers is damage.
4) RMS your Spks, for replace. or warranty.
5) try in another computer. ( if apply)
Jan 23, 2008 | Harman Kardon SoundSticks II Computer...
Hi, Kazim
Firts things First:
good luck
Jan 21, 2008 | Harman Kardon SoundSticks II Computer...
Subwoofer - no sound
Had the same problem when mine first arrived. Unplug and replug the power cord at the back of the woofer. Worked for me!
May 16, 2007 | Harman Kardon HARMAN/KARDON SOUNDSTICKSII...
Harman Kardon SoundSticks II Computer Speakers Logo
508 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Laser Plus Computers...
Level 1 Expert
 Grubhead
Grubhead
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
