Harley Davidson Master
- Posted on Sep 27, 2013
Re: How do I retrieve trouble code on a 2002 Harley...
Remove the right side cover to access the data link connector.
Remove the protective plug from the data link connector.
Connect a jumper wire to the first and second terminal on the data link connector.
Turn the ignition switch on and wait for 10 seconds. The light will turn on for 4 seconds, then off for 6 seconds. After this 6 second interval, any stored trouble codes will appear as sequential flashes.
Count the number of times the lamp flashes; this is the first code. The code will repeat three times before playing the next code, if any, after a 3 second pause.
Record the codes and refer to your service manual for possible faults or conditions.
Turn off the ignition switch and remove the jumper wire.
Replace the right side cover.
Read more: http://www.ehow.com/how_5556684_pull-engine-codes-harley-davidson.html#ixzz2g8gNkq5I
