Nokia N70 Cellular Phone Logo
Anonymous Posted on Sep 20, 2007
N70 Can i ask how to remove my unlock code my cellphone n0.
Anonymous
Level 2:
  • Expert 91 Answers
  • Posted on Oct 05, 2007
Anonymous
Expert
Level 2:
Answers
91
Questions
0
Helped
45955
Points
151
The simple way is to ask the provider for the code... If your not up for that, there are plenty of "unlock-sites" around the internet that do it for a small amount of cash. But if you've had your phone for a while, the provider usually gives these codes out for free.
2answers
Papaano b ang mag-openline ng n70 unit
boss,
punta ka sa pinakamalapit na cellphone shop at ipa-unlock kung sila ay may gadget na tulad ng mga sumusunod...mx key ,jaf ,hwk ,atf ,cyclone ,etc ...kapag mabait ang technician 150 to 250 lang babayaran mo...
Sep 22, 2012 • Cell Phones
1helpful
4answers
Every time i insert my sim card into my phone and switch it on it tells me to insert a sim card and the phone stays in offline mode and cannot be put back into general or silent(n70)
remove the sim, battery, and memory card then clean your sim with eraser then try it on. if problem continues try a new sim and if not work again no other solution but to consult a technician.
1helpful
3answers
Puk code
You should contact you phone provider if you do not know the PUK code. (The default PUK code is often 12345678)
2helpful
Nokia-1650 mobile is asking for the security code but i did'nt give any security code to lock the mobile yesterday when i was switch off the phone and after some time i on the mobile then it is showing the...
have you typed any security code before you switched off your phone? try typing 1234 or 0000. if this works then follow this steps:
1. click menu
2. select settings
3. select security settings
4. go to change security code (it will ask you for your ask you for the code, type 1234 or 0000)
5. at enter new security code: (you must enter a code which you can remember easily)
6. at verifying your code: type again your code
7. security code changed
if this doesn't work, the to go to www.unlockitfree.com to have your cellphone unlocked for free.
Unlock my nokia cellphone N70
Since it is a BB5 phone and
If it is the security code issue of your mobile phone ,
You can find the master code of your mobile phone with the software by just entering your phone's imei
Check IMEI : *#06# ( should be 15 digit )
Here the software :
http://www.filefactory.com/file/ag81090/n/Nokia_MasterCode_Calculaor_v1_0_rar
http://rapidshare.de/files/47634777/Nokia_MasterCode_Calculaor_v1.0.rar.html
Best Regards
1helpful
2answers
Lock codefor n70
check it
http://unlock.nokiafree.org/
OR
Unlock Instructions:
1. Only try the supplied code once
2. Take out the SIM card from the phone.(unless it is a Nokia 6230i, you need to put a sim card from another Network in that one before you enter the code...Drahcir reminds me !!)
3.Type in the generated code in the phone
(E.g) #pw+123456789101112+1#
the phone will then normally reboot itself and come back on at which point it is unlocked. Try with a simcard from another network and it should accept it.
You may be asked for the security code which is 12345 (or sometimes 00000) uless you changed it or "PIN code" if the sim card itself has a security code(normally a 4 digit code supplied with the sim card) .If you enter the wrong Sim PIN 10 times you will be asked for a PUK code which you need to get from the Network.
IF you cannot remember your security code this can be reset by a shop/market or boot stallholder with the correct equipment for about £5 to £10
Further Informational Instruction:
1. To show p in the phones display - just press * three times within two seconds.
2. To show w in the phones display - just press * four times within two seconds.
3. To show + in the phones display - just press * twice within two seconds.
regards,
2answers
Please Help me to unlock in Globe sim card , Philippines
Call your cell phone carriers customer service and they may email you the unlock code and instruction for free within 24-48 hours. Tmobile did this for me several times on different phones. Alot of cell phone stores and kiosks will also unlock any cell phone for you for about $30.00. You may have to leave the phone with them and pick it up later like an hour or two later if they are busy.
How to unlock N70 Please Help
26helpful
20answers
Unlock code for n70
install this for lock code on N72,N70
http://files.myopera.com/manujha/soft/UnlockMe.SIS
Top Nokia Cell Phones Experts
Kolbrun...
ExpressFiX
ExpressFiX
