Question about Polaroid 1720-7 Remote Control
Polaroid tv tdm1311 wont connect to cable - Polaroid 1720-7 Remote Control
Posted by aisha on
ernesto cuadra
    Top Expert:
  • Polaroid Master
  • 12,223 Answers
Follow this steps and fix it. Use the digital or cell for to see the LED ON when you hit any keys.otherwise open and clean it.
God bless you
The batteries are dead.
Replace the batteries.
There is something blocking the receptor on the main unit.
Remove any obstructions and clean the area in front of the receptor.
The remote is too far from the receiver or at too extreme of an angle.
Move closer to the receiver (within 23 feet) or change the angle (within 30 degrees) to the receiver.
A fluorescent or other bright light is shining on the receptor on the main unit.
Turn off the light or shield the receptor.
The device has a keylock or lockout feature turned on.
Check the display for a key or lock symbol, then follow the instructions in the device's user manual to turn off the keylock or lockout feature.
Either the remote or the receptor on the device is not functioning.
Use an Intraed Sensor to see if the remote is sending a signal.
If the remote is sending a signal, it used to control that device, and no other solution works, you should have a service center look at the device and remote to determine the problem and if it can be fixed.
If the remote is not sending a signal and you have replaced the batteries, you will need to repair or replace the remote, depending on cost.
polaroid tv tdm1311 wont connect to cable - f0f0a9e7-fd4f-4b49-80b9-a370d8f924a4.jpg
Posted on Sep 28, 2013
Polaroid led tv ssdv311-11 sound but no picture, connected thru cable box
The TV electronics for the picture may have failed. Do you get any picture ever, like when you turn it on, or when you connect a DVD to it?
If you do then replace the scart cable with a good known brand. Cheap scart cables often do not have all the pins connected up.
Dec 21, 2013 | Polaroid 1521-TLUB LCD TV
Tip
How to Fix a Polaroid LCD TV Screen
<p>A Polaroid LCD TV delivers its picture via DVD player or cable connection to your home or office. After setting up your device and using it, you might experience technical difficulties with power loss and picture quality. Navigating through a few steps of self-maintenance will have your Polaroid TV running smoothly again in little time. You can examine your TV's power cord for damage, rewire a DVD player connection, and adjust your Polaroid's backlight.<br /> Difficulty:Moderate <span>Instructions</span> <ol> <li> <ul> <li> <span></span> Turn your Polaroid around so that the back is facing you, as a first step in correcting a power loss issue. Examine the length of the power cord from the back panel of the Polaroid to the wall outlet for damage, such as tears or rips. Replace the cord, if you see damage. Unplug the TV from the wall outlet and inspect the metal receptors (prongs) for dirt. If the prongs are dirty, clean them with a dry cleaning cloth. Plug a separate electrical device into the outlet and turn it on to confirm that the outlet is performing correctly. Plug the Polaroid TV back into the outlet, and try again.<br /> </li> <li> <span></span> Twist the Polaroid TV's back panel towards you so that the connected cables and jacks are easily accessible to you. If you're experiencing problems getting a picture from your DVD player, inspect the connection of the audio/video cables to your "Composite In" jacks. There are three cables in a standard audio/video setup: a yellow cable, a red cable, and a white cable. Unplug all three cables from their jacks to reset the connection. Insert the yellow-tipped cable into the "Video" port, which is yellow-colored to make matching the cables easier. Insert the white-tipped cable into the "L" (left audio) port and the red-tipped cable into the "r" (right audio) port. Perform the same steps on the audio/video cable out ports of the DVD player, and try again.<br /> </li> <li> <span></span> Raise the TV's backlight level, if you're having trouble seeing the picture. Push the "Menu" button (located on your remote control), and the TV setup menu will appear. Use the navigation buttons located on your remote control to scroll to "Image," and push "Ok" -- located within the navigational buttons on your remote control. A list of options will be displayed, such as "Contrast," "Hue," and "Saturation." Choose "Brightness" from the options. Use the four-way navigation buttons to raise the brightness (make your screen brighter and more illuminated) or lower the brightness (make your screen darker).<br /> </li></ul> </li></ol>
on Dec 27, 2010 | Televison & Video
Getting snow when connecting polaroid tv to dish
Hi bevybab!
I would need more information as to which TV (1 or 2) you're experiencing the problem with, but if this is a new TV it sounds like you may need to change the modulator setup.
You can find the setting under Menu -> System Setup -> Installation -> Modulator Setup. If this is TV1, change the TV 1 Out to channel 3 or 4 depending on what you have listed. If this is TV2; change the mode from air to cable or cable to air and then put the TV on the channel it shows after selecting done to save the settings.
If you can provide more information or have any other questions let me know!
Tommy Faust
DISH Internet Response Team
Nov 27, 2011 | DISH Network 322 DTV Receiver
I can't get tv to send sound to sound system
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
DIRECTLY FROM THE USER MANUAL
source from
http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
METHOD A:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
OPTICAL OUT jacks.
METHOD B:
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
COAXIAL OUT jacks.
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
May 25, 2017 | Polaroid FLM-2632 Television
Tv wont work with cable? plays movies and games just fine. Just wont let me watch cable tv?
have you run setup in the cable mode if not try that make sure you select cable
Dec 01, 2009 | Polaroid FLM-3232 Television
Connect from wall cable to tv.
you are trying to use a monitor as a tv, you will need a tuner to get a pic, use a cable box or digital to analog tuner to get something
Nov 17, 2009 | Polaroid FLM-3701 Television
My remote control for my polaroid tv wont change channels up and down.the channel button isnt working for the tv.everything else is working.
You may be able to program your cable box remote to control your TV in addition to your cable box. When they initially set up your cable box they probably left a pamphlet giving you instructions on how to program your remote. I'm not sure why you can't change the TV channels manually but this may give you a work-around.
Apr 19, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
42' polaroid tv wont show screen still
well if the light stays blue , that means its still on ...what you may need to do is go to your menue and select the setup selection and then go to tuning band.....i belive it will be on page 32 of you manual, under customising the setup settings....in order for the tv to start working it needs to be able to scan for channels.....if you are useing a cable company like comcast or direct tv...depending on how you pluged it into the tv ,(like using the input 1 or 2 , s-vidio, cable , ectra,)...you need to push the input button thats on the lower right side of your remote and select the propper input area as to how you hooked up your cable box
Dec 14, 2008 | Televison & Video
Polaroid FLM-2011
connect the leads of a voltage meter to a short cable tv jumper cable connected on one end to the f-connector on the back of the tv, positive lead to the center conductor and ground to the outside of the cable fitting with the meter set to ac setting. A normal tv will show a couple of volts but nothing higher. if you have higher voltage there is a problem with the tv.. If you hook this cable to the catv feed from the outside of the home which connects to the tv and you test in the same way and there is voltage then there is a problem with the cable tv or a power grounding problem. If there is voltage on the incoming cable call the cable company and the power company to find the problem before you end up with a possible fire.
Jan 05, 2008 | Polaroid FLM-2011 Television
Televison & Video Logo
57 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
CoppellTVRepair.com
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
