Even caked-on iron and rust stains can be removed with a little effort. Apply your chosen cleaners to fiberglass tubs using a soft sponge, a nylon, polyester or polyethylene brush with soft bristles, or a soft cloth. Do not use abrasive cleansers, steel wool, abrasive scrubbers or scrapers on the fiberglass tub or shower surround, as these can scratch the fiberglass--in a gallon bucket: 2 tablespoons of white vinegar, 1/2 cup warm water, 1 2/3 cups of baking soda and 1/2 cup of a liquid degreasing dish detergent. Apply the solution directly to the stain and let it sit for an hour before rinsing and wiping clean.
A vinegar-and-baking soda paste applied to stained areas creates a chemical reaction that can remove the stain through the fizzing action generated by mixing backing soda with vinegar. Apply the vinegar and baking soda paste directly to the stained area and let sit for 15 to 20 minutes before rinsing and removal.
Normally a washer does not cause a staining problem, but If something inside the washer has rusted, it could. I would check your water tank. Drain water from the drain cock at the bottom of the tank, and see how dirty it is. If it is dirty, you need to drain the water until it is almost clear.
look at the arm that has the water nozzles on it to see if some of them are plugged. Also make sure the screen at the bottom of the machine isn't restricted.
There is a plastic cover on top of the drain. If you depress the two tabs on each side of the sprayer arms(bottom) and lift of sprayer bars. Reach dow and the plastic filter lifts right off. Many times this get clogged with debris. Also be sure and check that the drain hose has not fallen to the bottom of the sink cabinet. The hose must be above the garbage disposal and the hose runs into the disposal from there. Most times if you look under the kitchen sink and to the wall, u will see a nail or screw that the hose should be tied to. Hope it helps...
It sounds like you need to check the filters and clean them. It’s usually pretty simple to do but makes the dishwasher run like new. I think that it might be obstructed somewhere preventing it from being able to fully rinse the dishes. Is it draining all the water after the cycle has finished?
Several methods for cleaning the brown stains. Assuming they are rust stains you need to run a cycle without any dishes and a cleaner. Suggested cleaners are lemon juice or Iron Out. Some people use vinegar.
Racks should be available at your local appliance parts store or online. Appliance Parts at http://www.appliance-parts-warehouse.com and some at sears.com. Most are not difficult to install. Some require some thought to figure out how to get the old ones out.
Ok the problem with your washing machine is that there is grease and oil stuck in the machine and the oil will dribble out when you run the machine on a different cycle if you rince with cold water then the oil stays in there and the hot water lets a little bit out as it is stuck in the pipes of your machine ok the first thing is run an empty load on full hot water even the rince cycle with 1 cup of bleach nothing else let that go through the long cycle then do the same again with 1 cup of white vinger and 1/2 cup citric acid which you should be able to get over there or baking soda try that it will clean your machine and your pipes it is great way to keep it all clean by the time you have done this you should not have any brown stains
Have a great weekend
If it's gunk or build up the marks should wash away. In this case run a long cycle using "affresh" or "washer fresh" with an empty load and use the hottest water available to help rinse the gunk out.
If the marks do not wash away, it could be grease due to a bearing failure. Listen for loud growling or grinding either by spinning the drum by hand or putting it into a spin cycle. If this is the case, the rear tub assembly (contains bearing) will need to be replaced. Not much can be done about the ruined clothes :(
