Question about Windchaser Stainless Steel Patio Heater 40,000 BTU by - Model PHS
My Coleman 5040B750 Stainless Steel Patio heater will not stay lit. I was told that it likely has spider webs inside the gas tubing. How do I clean it?
1 Related Answer
Anonymous
SOURCE: Need Owners Manual/Assembly Instructions for WindChaser PHS Patio Heater
I have the exact same problem. No owners or assembly manual. Can get no response from company?
Posted on Dec 19, 2009
My 2 year old (rusted and looking like a 10 year old) Pilot goes on lights the heater, burns for about 2 minutes and goes out. I tried another regulator, same problem. Gas tank is full. The pilot light...
Heaters that have rusted are tin plated or chrome finish, it can be hard to get a stainless steel heaters since some traders sell heaters as stainless steel but don't tell you the burner is made of tin. If you get a new heater just ask the question, is the burner tin or stainless steel? The problem with a burner that goes out can be a simple as changing the thermocouple, these are consumable and last between 2 to 5 years depending on use and storage. But if you have a yellow tipping this is not good, this can be caused by wrong fuel mix or faulty gas valve and is not an easy fix. Found this site very useful patio heater problem solving. Lots of info.
Oct 23, 2011 | Coleman (5040B750) Patio Heater
Charmglow gas patio heater won't start
You got to heat the thermocouple to get the gas valve to open ... I guess you know that ... You checked for spider web???
Jan 18, 2010 | Coleman (5040B750) Patio Heater
The pilot will not stay lit.
No, the pilot light fine now. It will just suddenly go out. It may be fine for 12 hours and in the middle of the night it goes out.
Dec 11, 2009 | Coleman (5040B750) Patio Heater
The pilot light will not stay lit to light the heater.
The power pile (pilot generator) is defective. It produces a milivolt signal to ensure to keep the gas valve open. If it goes bad, the valve thinks the pilot is out, even when you are holding the button down, so when you release the button, it shuts the gas off to prevent excess gas buildup and a possible explosion.
Sep 10, 2009 | Coleman (5040B750) Patio Heater
Charmglow tabletop heater: how do I remove the dome?
First make sure you have propane. Low propane can cause this too. Presuming its not the easy fix, its probably spiders that have built a web in the venturi (air) tube.
Remove the screws attaching the screen/shield to the body and it can be lifted from the body without taking off the aluminum heat dispersing shield. Next remove the 4 screws holding the burner in place and you should be able to lift out the unit to clean of of the spider webs. High pressure water may or may not work. You may need to use something like a pipe cleaner.
Mar 08, 2009 | Coleman (5040B750) Patio Heater
Patio Heater pilot lights won't stay lit
crappy pilot flame (not properly heating the thermocouple), bad thermocouple, thermocouple loose where it screws into the pilot safety valve, bad safety valve magnet.
One or more of those is the problem.
Oh...there is also a saftey switch...in case it tips over. It will also cause the pilot to not stay lit (if the switch or wires that go to i are faulty)
May 30, 2008 | Coleman (5040B750) Patio Heater
My charmglow heater is a yeAr old and the pilot will ignite and stay lit for ever,but when you let up on it it goes out! What cam I do?
Mar 16, 2008 | Coleman (5040B750) Patio Heater
Heating & Cooling Logo
Top Windchaser Heating & Cooling Experts
Marvin
Marvin
Dennis Boxerman
Are you a Windchaser Heating and Cooling Expert? Answer questions, earn points and help others
