SOURCE: UL Code
Solved the unbalanced problem - open the top of the machine (press in with a flat putty knife about 3" in on the front on each side while lifting up as there are 2- 1" wide catches). Once both sides are unlatched, raise the lid then slightly lift the rear of the lid so that it fits into the curved part at the top of the hinges then open all the way - tape the lid to the top so it doesn't flap about and scotch the lid to keep it from falling back down on you. Now, look around - see all that rust? The rust has fallen into and gotten underneath one or more of the 4 white plastic suspension "ball joints" which have probably totally dried out by now from their factory grease because of the water, bleach, and rust particles. Having someone help you, simply lift up on one of the 4 corner suspension rods - gravity and weight is all that holds them down. The white ball will lift out of the socket and still be attached to the rod. Clean out the rust, lightly sand the "socket" with emery cloth, then slop in a fingerful of grease. I used automotive wheel bearing grease with graphite in it. Also scrub off all embedded rust on the white plastic ball. Lower that corner back into the newly cleaned and greased socket and repeat for the other 3 corners. Now when you move the tub around notice how the balls pivot in their sockets like they are supposed to. When they were dry and rusty they wouldn't move enough to allow the tub to twist like it should so it slammed around. Now, shake your head in disgust that after only 2 years there is so much rust that you wonder if it will make it another year before falling apart, close the lid, and try another load. That totally solved my off-balance problem where even a single handkerchief would give the UL error. It is still a finicky machine, but at least once again works like it did when new.
SOURCE: Every load Ul code in spin
HI,. this codes represents a control board fault. you will need to replace the Machine and motor control board.
This board is a all in one unit. it controls the basic logic points and the motor as well. It is damaged.
SOURCE: ul code about 10 to 15 seconds into spin cycle
Hi
Thanks
for using FixYa. UL is
displayed when the machine/motor control detects an off-balance load, and is
steady on while the washer runs a mini-cycle to rebalance the load.
• Display
clears if mini-cycle successfully rebalanced the load.
• If
the mini-cycle is unsuccessful, uL will
flash until the door lid is opened, allowing the customer to view and
redistribute the load. Please do rate the solution if the issue is
resolved or post a comment for further assistance.
Thanks
Rylee
SOURCE: cabrio washer with uL code. Will not operate
if it went thru the mini-cycle to redistribute the lad of clothes and it continues to flash uL then open the lid and manually redistribute the load,if this doesn't correct the problem,then try unplugging the unit for 15 minutes to re-set the ecu control unit and re-plug in and retry it
SOURCE: my cabrio waher will not spin on the last 12 min
My washer dose the same thing even with no clothes in it, cause i'v leaveled it and redistrbute the clothes in nothing wroks
