Question about Tomtom XXL 540S GPS Receiver
N14644 resetting unit starts after push and hold on/off button for 20-25 seconds then it shows on screen the all specifications. there is one item highlighted with red line it says (sector protection======NO
Posted by mramadan23 on
LP
  • Tomtom Master
  • 514 Answers
Seem your GPS device storage media (disk) has problems or the data may be corrupted. Try using the disk check utility on your computer to scan / fix the disk & data first. Then try it again.
If the GPS still doesn't work (after doing the disk check), try to restore the disk content from your back-up.
Posted on Oct 17, 2013
2 Related Answers
Anonymous
SOURCE: Tomtom 720GO wont turn on
The problem was solved as described in my posting of Aug.15,2009
Posted on Aug 16, 2009
Kris
SOURCE: i push start button and
The issue could be a low power in the Tomtom and that is the reason it is not switching on. Now here the problem could be with the charging cable/wire from the car charger which might not be giving power to the GPS. Check for the fuse at the connector.
If the fuse is blown off the power wont goes into the GPS and it wont get charged and wont swich on. Look at the tip of the connector which has that spring like contact. You will be able to turn that to open it and find a fuse. Replace it with the right "amp" as the existing one. You will get one from Radioshack.
If you have already checked it and sure it is charging could be issue with Tomtom itself..Good luckKris..
Posted on Jun 18, 2011
How to reset, when my android zeepad won't work by holding start and volume same time, nor does the reset button do it
Many people say to push and hold down the Volume(+) and Power button at the same time. Push and hold for as long as twenty seconds until you see a green android with green text.
But, on some devices and some Android O/S versions it takes pushing and holding the Volume(-) and Power button and holding them both down for twenty seconds or so or until you see the green Android and text screen. This will show the Wipe Data/Factory reset option. Select this option by scrolling using the Volume(+) button and engage using the power button. Some devices give you a second screen with a list of *no no no no no* and one line of Factory Reset. Again, scroll to the Reset option using the Volume(+) option and select it using the power button.
If the above doesn't work, either your battery is dead or your device is dead.
May 15, 2015 | Tablets & eReaders
Tip
How to Reset Your Air Conditioner Filter Light
<span style="font-weight: bold;">Cabin Air Conditioner:</span><br /> <ol> <li>Press and hold down the Off button for 4 seconds.</li></ol><span style="font-weight: bold;">Carrier Air Conditioner:</span><br /> <ol> <li>Press the Reset Filter button to reset the timer that calculates the next air filter change after you have inspected / cleaned the indoor return air filter.</li></ol><span style="font-weight: bold;">Daikan Air Conditioner:</span><br /> <ol> <li>Press the Filter Clean Reset button to reset the CLEAN FILTER INDICATOR after you have inspected / cleaned the indoor return air filter.</li></ol><span style="font-weight: bold;">Frigidaire Air Conditioner:</span><br /> <ol> <li>To reset after cleaning the filter, press the "Filter Reset" button and the light will go off.</li></ol><span style="font-weight: bold;">GE Air Conditioner:</span><br /> <ol> <li>Turn the air conditioner OFF and unplug it.</li> <li>The air conditioner must be unplugged for the automatic filter clean timer to reset. Clean the filter.</li> <li>After cleaning, replace the filter and plug the air conditioner back in.</li></ol><span style="font-weight: bold;">Honeywell Air Conditioner:</span> <ol> <li>Press and hold the i button until the timer is displayed, followed by pressing the Up Arrow button (next to the Wake button)</li> <li>Press the Run Program button.</li></ol><span style="font-weight: bold;">Kenmore Air Conditioner:</span><br /> <ol> <li>To reset the filter indicator, press and hold the filter reset button for 3 seconds.</li></ol><span style="font-weight: bold;">Lexus Air Conditioner:</span><br /> <ol> <li>Without having foot on the brake, press the Start button twice to get to the IG-ON position.</li> <li>Then press and hold the "hard" OFF button next to the "hard" Auto button. Hold the OFF button for approx 5 seconds and you hear several beeps.</li></ol>or<br /> <ol> <li>Turn the engine switch to IG-ON mode.</li> <li>Push and hold the A/C OFF button for more than 4 seconds.</li></ol><span style="font-weight: bold;">Lexus 2008 Air Conditioner:</span> <ol> <li>Push the "INFO" button & touch "Maintenance".</li> <li>Touch the desired button Delete All: To cancel all conditions which have been input or Reset All: To reset the item which has satisfied a condition. If "ON" is selected, the system gives maintenance information with the "Information" screen when the system is turned on. If "OFF" is selected, the "Information" screen is disabled.</li> <li>Input the Notice of Date: The next maintenance date must be input.</li> <li>Now input the Notice of Distance: The driving distance until the next maintenance check.</li> <li>Delete: To cancel the date and distance conditions.</li> <li>Reset: To reset the date and distance conditions.</li> <li>Touch "OK" The screen returns to the "Maintenance screen.</li></ol><span style="font-weight: bold;">Lincoln LS 2001 Air Conditioner:</span><br /> <ol> <li>Press and hold the setup button above the radio until it says system check. NOTE: All the doors must be closed.</li> <li>Watch the system check when it goes to A/C filter hit the reset button.</li> <li>Hold down the reset button to confirm.</li></ol><span style="font-weight: bold;">Lincoln LS 2003 Air Conditioner:</span><br /> <ol> <li>Press the STATUS control to access the System Check function, the message center will display A/C FILTER XX% RESET FOR NEW.</li> <li>Press and hold the RESET control to set to 100%.</li></ol><span style="font-weight: bold;">Lincoln LS 2005 Air Conditioner:</span><br /> <ol> <li>Insert the key and turn the ignition to "Run" or "On." It is not necessary to start the engine.</li> <li>Press the "Status" button above the radio until the system display changes to "AC Filter."</li> <li>Press and hold "Reset" above the radio. The system will beep and the "AC Filter" display resets to "100%."</li></ol><span style="font-weight: bold;">Maytag Air Conditioner:</span><br /> <ol> <li>Press the "Fan" button 2 times, then press the "Mode" button 1 time and it will reset.</li></ol><span style="font-weight: bold;">Whirlpool Air Conditioner:</span><br /> <ol> <li>Push in the filter reset on the remote using a straightened out paper clip or similar.</li></ol>or<br /> <ol> <li>On the control panel, press and hold the Mode and the Up Temp Arrow buttons for 6 seconds.</li></ol>or<br /> <ol> <li>After having cleaned the filter just press the reset button located on the indoor unit behind the front panel to interrupt the flashing of the filter monitor indicator.</li></ol>
on Jun 17, 2011 | Heating & Cooling
How do I reset my tomtom n14644 to factory settings
If you couldn't reset it holding the power button for 1 minute, yor Tomtom is defective and you should take it for service
Feb 10, 2015 | Tomtom GPS
Want to know what buttons to push on settings panel to reset the computer on my vz commadore after the service is due How to reset service warning light?
1. Turn Igniton off
2. With ignition 'OFF' press and hold both arrow buttons, turn ignition on.
3. Release buttons after 3 seconds - the reset reminder should be flashing.
4. Press and hold set button for approx 3 seconds or until beep.
5. If you need to reset oil service - Press and hold set button again for approx 3 seconds or until beep. 'Service Reset No Items' should show.
cheers
Jan 16, 2013 | Cars & Trucks
How to unlock my coby
This is the "master" reset procedure. No other way of clearing the unlock pattern.
*******This procedure will delete all items (file's) and entries on the unit******
Step 1- Power the unit off. Press and hold the "Power Button" till the "Device Option menu appears.
Step 2- Click on "Power Off and select "OK" .
Step 3- Once the unit has been turned off. Press and hold the "reset" button and "power" button simultaneously for eight seconds.
Step 4- The following screen will appear. Press the "reset" button.
Step 5- The Android system recovery screen will appear.
Step 6- The "Home and Menu" button will allow you to go Up and Down the Android system recovery screen.
Step 7- Press the menu button to go to "wipe data/factory reset". . Press the "reset" button.
Step 8- The following screen will appear. .
Step 9- Press the Menu" button to select "Yes- delete all user data".
Step 10- Press the "reset" button.
Step 11- The following screen will appear .
Step 12- Press the "reset" button to reboot/restart the unit.
Aug 18, 2012 | Coby Kyros 716829701508 Tablet PC
Tried to reset the intermatic timer. But, the timer won't turn off
You posted under self-adjusting Intermatic, which I assume is ST01C
Add a comment if you have different timer.
I had the same problem resetting my ST01C because I was pushing reset button without holding down ON-OFF button.
But my timer is fairly new and hasn't malfunctioned.
A lot of folks write-in about ST01C that just doesn't work any more.
To reset timer: hold down ON-OFF button, and then use paper clip and push reset for full three seconds.
Release reset but keep holding ON-OFF.
Keep holding ON-OFF button until INIT shows on screen.
Release ON-OFF and wait for timer display to show.
If timer display doesn't restore, then change battery with new CR2.
People write in after changing battery and report timer never came back to life.
So these timers are hard to figure. ST01C has 1 year limited warranty.
To re-program timer for specific hours instead of dawn-dusk, there are clear steps on link below
http://waterheatertimer.org/ST01C-program.html
Nov 28, 2010 | Intermatic & Self-Adjusting Wall Switch...
I have a digital wall timer that allows for settings over multiple days. Trued to reset it (remove a few memorized settings) by pushing 'reset'; but this had no effect. Do I need to press it for a longer...
You posted the question under ST01C timer.
This timer will clear all programs if you hold reset in for a few seconds until the screen starts blinking 12:00. The reset button is a small round button that you push with a paper clip.
The ST01C memory for current day can be cleared by removing battery for a couple minutes, but the day-to-day programming remains forever until timer is reset.
Each timer tends to follow the same pattern as described above when there is a small round reset that is pushed with a paper clip >> push, hold for a few seconds, timer resets.
Other timers have a larger button for Reset ... the timers with larger reset button usually require you to hold the clock button and reset button at the same time ... or some other button besides clock has to be pushed at same time with reset. You can try different combinations of buttons and hold both down for a few seconds.
If you reply to this response with your exact model and brand timer, I can look up the specifics for most timers
Oct 18, 2010 | Intermatic Inc. ST01C Digital In-Wall...
When i hit the lower right hand coner the unit responds letters above? the screen is not synced with where i push?
To reset the screen sync, press and hold the battery icon for a few seconds (you may have to press below it with your fault). You'll then go into a diagnostic mode, scroll through the screens using the buttons at the bottom until you get to a menu item which allows you to re-sync the screen. Eventually you'll cycle through all the pages to the start and can press exit to return to normal mode.
May 29, 2010 | Garmin nuvi 200W GPS Receiver
How do I reset my TOMTOM N14644?
Go to TOM TOM´s homepage http://www.tomtom.com/services/
Connect the GPS unit to the PC using the USB2 connection.
You will be given the possibility to restore the unit´s files. This takes a while, but it solved the problem for me.
Nov 04, 2009 | Tomtom ONE GPS Receiver
How do i reset the Netgear EN106tp to factory setting?
Hubs don't have any settings to reset. If it's a router, try the "30-30-30 reset." Get a pen, and hold down the reset button 30 seconds while the router is still plugged in. While still holding down the reset button, unplug the power, hold down another 30 seconds, then plug it back in, and hold down the reset another 30 seconds. The reset button is a small black button that you'll need a pen to push.
Sep 30, 2009 | NetGear EN106TP Networking Hub
Tomtom XXL 540S GPS Receiver Logo
60 people viewed this question
Top Tomtom GPS Experts
k24674
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
