Question about Electric Health & Beauty
I have a Quantum power chair. I had an error message #1 reading on the display screen also it said STOP. What does this mean?
Posted by Susan Woods on
ernest a fleming
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 105 Answers
Think that is a user fault, release joystick to nuetral and try again
Posted on Jan 20, 2014
Quantum 600 power wheelchair. From time to time chair stops abruptly, low battery appears on controller screen even though battery is fully charged.
There is a 51 page MANUAL here:
Quantum 6000 Owner Manual
See this link for 1,500 Troubleshooting results:
quantum 6000 wheelchair troubleshooting Google Search
You may be looking at a sudden/intermittent electrical short OR one of your connectors may be loose?
http://www.thewiringbooks.com/wiring/quantum-6000z-wiring-diagram.html#gallery-1
Your chair voltage REGULATOR may also be going bad which appears to be WITHIN the "Main Brain" of your chair?
"TECO FM-50"
regulator-gkhd23p0qwnavtoilob1hbhw-1-2.jpg From the above schematic ~ there is a "Potentiometer" shown (lower left) that MAY be 'dirty' and needs a tiny squirt of "QUALITY" contact cleaner WITH SILICONE to help keep the internals clean... looks something like this (a Google Search):
I would also spray ALL of your control switches too including the inside of your joystick controls! Just a REAL QUICK squirt should do it... if it drips, you've used too much.
I hope this HELPS YOU!
Anthony
Apr 17, 2018 | Televison & Video
I have quantum pride 610 chair when l power on it show me an error . The errorcode#36 release joystick .please l want some help
i think you will have to ring your support team and carers asap
get someone to test the power control module under the seat or the joystick controller
the batteries must be charged to get the error message
this the quantum pride 610 user manuals
http://www.pridemobility.com.au/default/assets/pdf/Owners_Manuals/US_Q610_Aug13.pdf
Apr 30, 2016 | Pride Health & Beauty
It started running lower and lower even thought it was fully charged, now the last couple of day I've been getting bus overload and it will not charge
Quantum 6000 - Pride Mobility Products
www.pridemobility.com/pdf/owners.../au_q6000_om.pdf
Pride MobilityQuantum 6000 .... WELCOME to Quantum Rehab, a division of Pride Mobility Products ... The symbols below are used on the power chair to identify warnings, .... Lowpressure may result in loss of control, ... If you must stop, start up again slowly and then accelerate .... Avoid tall grass that can entangle the running gear.
[PDF]Quantum 6000Z - Pride Mobility Products
www.pridemobility.com/pdf/.../intl.../au_q6000z_om.pdf
Pride Mobilitythis power chair and must perform all of the procedures in this manual. The symbols below are used throughout this owner's manual and on the power chair to identify ... NOTE: The Quantum 6000Z and its components are not made with natural ..... Turn the adjusting screw to raise the front of the armrest or to lower the front ...
Pride Mobility Quantum Q6 Edge (Power Wheelchairs ...
www.usatechguide.org/itemreview.php?itemid=1626
35 posts - ‎30 authors
Feb 05, 2016 | Quantum 6000 Power Chair - Used Electric...
My quantum 600 wheel chair won't work it says system lock
My quantum 600 wheel chair won't work it says system lock ...
www.fixya.com/.../t26033304-quantum_600_wheel_chair_work_says_s...
2 hours ago - My quantum 600 wheel chair won't work it says system lock -Wheelchairs question.
Quantum 6000 or 600 Rehab Power Wheelchair - CareCure Communitysci.rutgers.edu/.../showthread.php?...Quantum-6000...Rutgers UniversityJul 4, 2008 - 10 posts - ‎9 authorsI had the QUANTUM 600e Rehab Power Wheelchair for six months. ... C-500 Hvy dutypower chair w/hi-speed motors, power seating system, .... I have a Q600 with tilt, recline, leg extension, Q-logic..pretty much the works. ... the thing shuts itself off andwon't move when I have anything under 90% charge?Quantum® 600 Power Chair Reviews - Pride Mobilityownersclub.pridemobility.com/reviews/item/1/20The Quantum® 600 Power Chair delivers the stability of patented Mid-Wheel 6® ... At that same time the 3rd motor set was changed my seating system was ... We were rescued by boat and my friends say the wheelchair was working ... Insurance won'tcover a power chair for me yet so I had to pay out of pocket for this one.
Jan 01, 2016 | Health & Beauty
Push power button wont go but all the adjustments legs back tilt works
quantum 600 wheelchair troubleshooting Questions ... - Fixya
www.fixya.com > Forum > Tags
quantum 600 wheelchair troubleshooting chair won't go all i get form joystick is a picture of a ... around in a square there should be a rest button on the rear of the chair ,push ... Question about 600 E Electric Wheelchair - Used Power Chair.
[PDF]Pride Quantum 600 Owners's Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600%20Owner's%20M...
Quantum 600 .... The symbols below are used on the power chair to identify warnings, mandatory actions ... Pride will not be held responsible for injuries and/or property ...complete stop by releasing the joystick, then push the joystick forward slightly to .....breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600E Owners Manual - Scootaround
www.scootaround.com/.../Pride%20Quantum%20600E%20Owner's%20...
Quantum 600E .... The symbols below are used on the power chair to identify warnings, mandatory ... chair. Pride will not be held responsible for injuries and/or property ... complete stop by releasing the joystick, then push the joystick forward slightly to ..... breaker button, turn on the controller, and continue normal operation.
[PDF]Quantum 600 Series - Pride Mobility Products
Dec 30, 2015 | Quantum 600 E Electric Wheelchair - Used...
Wheel chair will not turn left
Check for intermittent left motor wire connectivity at 4-pin connectors red and black wires. This is a common issue with this model: motor power wires break inside the wires insulation causing jerking and eventual stopping of motor. Motor resistance should read between 1 and 3 ohms. If this is the issue have the motor rebuilt.
Mar 14, 2014 | Quantum 614 HD Power Chair - Used Electric...
Moving very slow
Hi, i seen this before, whoever fitted the batteries needs to double check the connections. One customer needed the brushes replacing so it may well be worth checking ...
Regards
Rob
www.gewizrepairs.co.uk
Mar 06, 2014 | Quantum 6000 Power Chair - Used Electric...
Charger inhibit error
Hello Debbie Waters,if you contact a Wheelchair/Scooter Repair Shop.Give them what you see as to (WHY) & ask for a price on the Part.I hope this has helped,Colin.
Jan 16, 2014 | Quantum 6000 Power Chair - Used Electric...
Error 1203
hi..
error 1203 means either or both cartridges have short circuited and needs replacement..
You will need to perform the following steps to find out which cartridge is defective:
1. With the printer turned ON, open the front cover and remove both cartridges from the printer.
2. Power the printer OFF and unplug the power cable for 30 seconds. Plug the power cable back in and turn ON the printer.
3. If the error message is now cleared from the printer, please perform the "Self-Test" by following the steps below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
If the printer has detected a "Cartridge Missing" error, then please follow the steps given below:
1. Turn the power OFF.
2. Open the front cover.
3. Turn the power back ON. The print cartridge carrier should move to the install position located in the middle of the printer. If it does not, close and reopen the cover:
4. Reseat both cartridges in the printer and check for the error.
5. If the error still displays, then remove the color print cartridge.
6. Close the cover.
7. If there is no error indicated by flashing lights, the color cartridge has short-circuited.
8. However, if you continue to get an error, repeat steps 1-3, and then go to step 9.
9. Remove the black print cartridge and reinsert the color cartridge.
10. If there is no error indicated by flashing lights, the black cartridge has short-circuited.
11. If you continue to receive an error in both cartridge scenarios, both print cartridges have short-circuited.
Apr 23, 2009 | Lexmark X5470 All-In-One InkJet Printer
Health & Beauty Logo
59 people viewed this question
Top Electric Health & Beauty Experts
Rob Hill
Rob Hill
barrybam
jws1013
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
