Question about Jet 3 Ultra Power Chair
HOW DO I REPLACE WHEELS ON MY JET 3? - Jet 3 Ultra Power Chair
Posted by Connye Karpel on
ernest a fleming
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 105 Answers
First thig is to jack up front or have someone help u lift the chair on a, box that that will just fit between the tires and then put in gear and take nut and washer off then pull tire off if u bought new tires without the rims u need to take to a tire repair shop and have them put them on for u then replace
Posted on Jan 20, 2014
Bmw 3 series abs fault
bit of dirt in abs ring
jet wash all wheels to clear the dirt
Jan 30, 2014 | 2001 BMW 3 Series
INVAMED SCOOTER IS RUNNING SLOW
Check condition of batteries. Be sure casters and anti-tilt wheels are turning freely. Be sure speed control buttons on keypad are free of crud and are advancing the LEDs.
Mar 11, 2013 | Jet 3 Ultra Power Chair
While charging batteries in what position do the levers for locking the chairs wheels go
You don't need to "lock" anything. While charging, the joystick is locked out already.
Apr 30, 2010 | Jet 3 Ultra Power Chair
Can you replace the wheels ? My wheels are quite worn down now, yet the body is still in excellent condition.
Yes, you can replace the wheels. Just visit ww.silvercross.co.uk for more help with purchasing the parts, or visit your retailer.
Hope this helps.
Mar 26, 2010 | Silver Cross 3D Jet Sport Standard...
Jazzy jet 3
Look in your owners manual for the flash code anwser. Make sure when you hit the power button you only touch it for 1 sec not more. If you press the power button for more the 2-3 seconds you place the power chair in LOCK OUT mode. lights will flash and not power. also check your free wheel levers. one on each moter. Mike
Sep 06, 2009 | Pride Mobility Products Jazzy 1103 Ultra...
Is there an electic cord or supply cord that goes from the joy stick to the battery?
of course, that's how the joystick communicates to the wheels....they wear out very easily if you push the joystick too hard/far.
Aug 01, 2009 | Jet 3 Ultra Power Chair
My wheels are not turning on my Polaris 280, what can I do?
When my polaris wheels stopped spinning it was the water jet which spins the turbine was clogged. The in-line filter had failed and some small debris had passed through to clog the jet. Easy fix to take off the top cover then take off the turbine cover and examine /clear the hose (clamped on by zip ties) and the plastic jet.
Jul 27, 2009 | Polaris 280 In - Ground Pool Cleaner with...
Polaris 380 wheels not moving
Here are some things to check: 1.  There are belts inside the unit that drive the wheels.  These belts often fail (shred) and must be replaced. 2.  There is a paddlewheel that drives the turbine that turns the wheels.  If the jet that drives the turbine is clogged, then the paddlewheel will not move and the wheels will not turn. 3.  There is a water management system inside the bottom of the unit.  It looks like a bunch of little hoses.  If one of these hoses comes loose, then the water pressure will escape inside the unit and will not be sufficient to drive the wheels.
Hope this helps
Jan 09, 2009 | Polaris 380 In Ground Pool Cleaner
Jet 3 Ultra Power Chair Logo
81 people viewed this question
Top Jet Health & Beauty Experts
Marvin
Marvin
Vincent G
Vincent G
ray gallant
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
