Question about Health & Beauty
Rebuilt motor installed in Pronto m50 power chair, now joystick forward, takes chair to right, joystick right takes chair forward, joystick to left, taks chair back, joystick back takes chair left, HELP
Posted by Gary Brooks on
ernest a fleming
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 105 Answers
U need a programer o reset that joystick to the new motor,so call the dealer have them send out a qualified tech with a programer to check error codes and reprogram
Posted on Jan 20, 2014
5 Related Answers
mas Didiet
Reviditta Harmawan
  • 17 Answers
SOURCE: rascal power chair runs backwards.
Check your controller program using PP1programmable for PG drive controller ( VSI,VR2,and Pilot+) or using Dynamic wizard for Dynamic Controller (DX,DL,Commando,SHARK, and RHINO)
Regards,
mas Didiet
Posted on Nov 13, 2008
lennieg2000
  • 692 Answers
SOURCE: jazzy 1121 power chair won't charge when plug in
you have either bad batteries or a bad charger or the charger might have come unplugged at the controller or power module. When you have the charger plugged in and you turn on the joystick the lights on the joystick should ripple to indicate the charger is plugged in. If you don't see this ripple then either the charger is bad or disconnected. Trace the charger cable from the rear of the chair (you have to remove the seat and shroud to do this) to the front module and make sure that the cable is plugged in. Hope this helps
Posted on Oct 23, 2010
wcdoc1953
wcdoc1953
  • 280 Answers
SOURCE: i have oil leaking onto the left side tire of my
Sounds like you have a blown seal on your left gearbox. The only permanent solution is to replace the left brake/motor gearbox assembly. Not exactly a do-it-yourself repair. to verify, you can pull the seat off to inspect with a flashlight or tip the chair up at 45 degrees on the right drive wheel to inspect.
In my experience this is a common problem. It may take some time for enough gearbox grease to ooze out and cause the gearbox to fail. If you run the chair inside the house it will get messy very quickly and the grease stains are difficult to remove. If the chair is upwards of 4 or 5 years consider replacing left and right motor/gearbox assemblies. Hope this helps.
Posted on Dec 17, 2010
lennieg2000
  • 692 Answers
SOURCE: I have an Invacare Pronto
mad check the freewheel levers under the front of the seat on the base make sure that they are in the drive mode turn the chair on and you should be good to go. Have the power off move the levers back and forth and leave in the drive mode then turn the power on and you should see normal lights and operation Hope this helps
Posted on Apr 07, 2011
lennieg2000
  • 692 Answers
SOURCE: When I turn on controller
Do all of the speed lights flash at the same time or do they ripple from left to right? If they ripple from left to right the chair is in lock mode and you can use the unlock procedures from my tips to unlock. If they are all flashing at the same time you have an internal joystick problem and the joystick needs to be replaced Hope this helps
Posted on Apr 28, 2011
Lights flash right to left then shut off. Cant get chair to turn on
You are locked out.
turn on push horn 2 times quickly.
or turn on push joystick handle forward all the way until it beeps then back all the way until it beeps. there you go!
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Dec 01, 2015 | Electric Mobility Invacare Pronto M41...
Unlock a spj+ joystick on a pronto m41
Lets make sure this is just the joystick lock mode. When you turn the chair on and it is in joystick lock mode all the battery level lights will chase across several times and then the joystick will turn off.
When you turn the chair on and you see the battery level lights chasing from right to left push and hold down the power button till the lights turn off. Only the first year that the M41 was made had this option.
Jan 23, 2015 | Electric Mobility Invacare Pronto M41...
Power steering electric
If the chair wants to drive left then you have a disengaged left motor clutch lever or a left motor going bad. Then M51 will not give an error code if the clutch is disengaged. If the chair is veering left as you are driving but you are still able to turn to turn right then the motor is not likely to be disengaged but has a brush or gear problem.
It is also possible that the joystick is not working well. The joystick is much less likely to be the problem unless it is damaged somehow.
Sep 02, 2014 | Invacare Pronto M51 Power Wheelchair
I have a Quickie S646SE wheelchair with a Qtronics Pilot+ romote controller. I charged the chair last night. When I turned it on today the profile lights scroll left to right and the chair does not move. I...
Press and hold power button til beep then push joystick forward and hold joystick til beep then pull the joystick back and hold joystick til beeps. turn power off then on. should be unlocked now
Mar 17, 2014 | Quickie Wheelchairs Quickie S-646 Power...
Locking a power chair
turn off, press and hold on button til it beeps, push and hold joystick forward til it beeps, pull and hold joystick til it beeps, it is now locked... repeat to unlock
Nov 12, 2012 | Invacare Pronto M51 Power Wheelchair
Wwe have a pronto m41 mobility chair.the service indicator light is telling me its a right brake problem can i fix this and how. also the led lights are chasing left to right. i have to get this working...
First thing you must know is that the error codes are reversed on Pronto chairs with SPJ+ joysticks.
Only one year the M41 was made that the codes were correct. From approximately April 2008 to May 2009 was the only time a left error code ment left motor and a right code ment a right motor. Same for brake codes.
Brakes codes happen when the brake is out of gear, unplugged from the control brain or wire cut. Also from internal coil damage. Unless it's a wire you can reconnect you cannot fix the brake.
Dec 23, 2010 | Electric Mobility Invacare Pronto M41...
The charge indicator lights flash left to right..when moving joystick the chair does not move.
chair is locked out. turn on then push joystick forward till it beeps then pull backward till it beeps then it is unlocked
Jun 15, 2010 | Invacare Pronto M51 Power Wheelchair
Chair pulling to the right and going in circles
Check the brushing in the right motor. It can't hurt to replace them. Then if the problem continues, have the motor checked out.
Aug 29, 2009 | Invacare Pronto M51 Power Wheelchair
My wheelchair dose not move
The chair has two levers, one for each motor, that disengage it for freewheeling, or pushing the chair without power. These take it out of gear. Place the levers in the locked, gear-engaged position and it should go for you. Here's a link for the manual for your chair, and it will show you where the location is to place it in gear.http://www.invacare.com/doc_files/1125085J.pdf
Apr 16, 2009 | Invacare Pronto M51 Power Wheelchair
Health & Beauty Logo
116 people viewed this question
Top Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Are you a Health and Beauty Expert? Answer questions, earn points and help others
