if you open up the hood and look on top of the transmission you will see a gold colored arm connected to a rod or cable this cable or rod probably came dissconnected or broke just rech in with some channel locks and move it possition by turning the gold rod shaft coming out of the transmission. it might not be gold it might be black depending on how dirty the engine is. if you have some one sit in the car and move the shifter you will see what needs to be moved. hope this helps
If your car is auto, there should be a cable going from the shifter to the ignition to stop you being able to remove the key unless the car is in park. If the cable has become dislodged or broken your key won't come out. I would remove the shrouds around the column and have a look at the back of the ignition while moving the ahifter in and out of park. If your car is manual , I would suspect a bent key or a contaminated lock ( not common in a car this age ) Try Graphite powder, ( messy but effective ) it should be avaliable from your hardware store. Good Luck!
push key in turn on and off push key in work switch off and on .if dont release you probably going to have to take out the ignition switch. make sure your car is all the way in park.
Next to the shifter (on drivers side) there is a small rubber plug. If you remove the plug and push the end of a key down in the hole, it will relase the shifter. I ended up taking mine in after having the same problem several times and it was pretty inexpensive to fix.
There a several recalls that deal with this problem, it seems that due to a defective part in the ignition interlock system at times the key not be removed from the ignition, it appears the issue is corrected by installing a new lock cylinder, to read the full text of recalls on this issue go to link listed below.
