Nokia N70 Cellular Phone Logo
Posted on Sep 19, 2007
Nokia N70 Lcd Problem
The phone was in the water, i managed to fix it but the Lcd on the phone is blank. If i remove the Lcd from the phone and put it in another phone it works. i understand that i need to replace a crystal i don't know where the crystal is on the board
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Sep 19, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2215
Points
10
Obove the lcd connector there is 2 black bga's / chips change those two it will work 100%
1helpful
My cell phone(nokia n70) is not diplay any operation. but the monitor is in order .what can ido?
Only 2 reason for blank lcd on N70,first lcd socket and the screen it self and 2nd Display IC (It need help from service center). to make sure Open your phone cashing and also all the screws.than release a LCD socket from VCB clean socket on VCB up with a thinner or alcohol. becarefull when cleaning lcd socket use a tooth brush and not much alcohol because it can make a flex on lcd.Congratulation if it work but if still blank it mean display IC need to change.
1helpful
2answers
NO DISPLAY
So if you have a blank display or just a white one, replacing the lcd screen should fix the problem.
See the link below for a guide on replacing the N70 lcd screen and links to buy a new one from ebay.
How to Replace the LCD Display Screen on Nokia N70
2answers
Blank display
2helpful
My Nokia N70-1 phone has displaying it's Graphics wrongly?
Blank display, i can make and recieve calls but i'm not able to see my contacts,msg etc........
2helpful
2answers
Nokia n70 is showing white blank screen
possible the firmwar is damage or sum ics have burn because of a power spike, or brownage while it was on charge, take it to a repair shop to be checked
3helpful
Switch it on it gives light and a blank LCD display
You can reinstal its internal operating system from your near Nokia service center.
10helpful
3answers
6helpful
9answers
N70 Problem
Try a reset:
First turn it OFF, take the SIM card out.
Press * 3 send at the same time and turn power on. Keep them pressed untill the reset screen appears.
Give it time to work.
This might not work but it's worth a try.
I think your phone has been Black Listed.
It must have been reported stolen.
34helpful
5answers
NOKIA LCD PROBLEM
first u need to tell are u getting calls even when the phone is blank.
Top Nokia Cell Phones Experts
Kolbrun...
ExpressFiX
ExpressFiX
