BuyRite Faber - INPL3622SS Cooking Products : Range Hoods Logo
Palani Posted on Sep 26, 2013
Badly i need Faber cooking range user manual for gas
Faber model inca hc 72. The fan makes an odd noise. It still works. it is 11 years old.
your hood probably needs a service call to examine the motor, please visit http://faberonline.com/service.html to find your local service #, thank you
2answers
Parts -- # 133.0073.597
i need the same part. where did you order it from? thanks.
Sansui cooking range- S-905GS need manual
need image of this model s-905gs
Britannia si-12t76x2
If your oven has no heat you'll need a new oven element, if your oven is cooking food too quickly/burning at the back then you'll need a new fan, if the oven is burning everything you'll need a new thermostat, if the oven isn't working at all check that the clock/timer hasn't been set for auto ie make sure it is on 'manual cooking'
Hi i have astoves gas cooker, model 600gdoa and i
Stoves 600GDOa - when the glass lid is lifted to start cooking it turns on (anticlockwise direction) the switch, which turns on the gas - unlit. I wouldn't believe it unless it happened to me. At the moment the switch is taped shut but I would like some ideas.
1helpful
GE XL44 gas range, oven dial doesn't have "lite"?
Set the oven for the desired temperature. It will cycle on and off at that temperature.
It will lite automatically.
Switching from gas to oven
Your model stove is dual fuel. Which means that the burners on the top of your stove are run using gas, and the bake and broil (and possibly a warming draw) are run using electricity. So if you are cooking on the top of your range you are using gas, and if you cook in the oven you are using electicity
I need users guide
I need to replace oven light bulb for  Smeg gas oven range cook unable to take cover off to get at bulb any ideas how this is done?
Top BuyRite Cooking Experts
ADMIN Andrew
ADMIN Andrew
Billie Aukuso
Are you a BuyRite Cooking Expert? Answer questions, earn points and help others
