The copier doesn't copier but Shows the error message C710 instead. I bought the copier and when it arrived here there was toner all over it. So I assume the toner sensor is not clean or something like that. Where can I find the toner sensor and how do I clean it?
Replace the toner sensor
http://www.precisionroller.com/sensors-for-kyocera-mita-km1505/details_22773.html
Posted on Dec 26, 2013
SOURCE: kyocera mita km-2030 call service error
open the left side door and push in the drum unit firmly. it's the part above the waste toner
Posted on Nov 07, 2008
SOURCE: km-1510 .. AP error code
AP = Adding Powder (toner) it's not an error
it's adding toner from the container into the developer unit while displaying AP. when there is enough toner in the container the AP will disappear and copies can be made when there is not enough toner in the container the toner empty light will come on.
Posted on Jan 23, 2009
SOURCE: I have a FS-1118 MFP
yyou have to be careful when doing this.
the waste toner is built in to the process unit (drum unit) and has a plug on the side.
remove the plug and tip it out.
Posted on Mar 10, 2009
SOURCE: i already replace a new toner but there an error msg AP
Hi
The AP message indicates thet the dev is so low in toner that the machine has to go into a full cycle mode to get the toner levels up.
The error code is telling you that one cycle is not enough. you will have to turn the copier off/on and cycle it at least one more time....more if neccessary
Posted on Jun 22, 2009
Nov 24, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
Sep 26, 2008 | Copystar Office Equipment & Supplies
Apr 07, 2011 | Kyocera Mita KM 1510 Laser Printer
Sep 23, 2009 | Office Equipment & Supplies
Jun 14, 2009 | Kyocera KM-1505 Copier
May 17, 2009 | Kyocera Mita KM-1815 All-In-One Laser...
Feb 05, 2009 | ASUS P5GZ-MX Motherboard
May 27, 2008 | Office Equipment & Supplies
Feb 20, 2008 | Copystar CS-2030 Copier
Jul 07, 2014 | Kyocera KM-1505 Copier
345 people viewed this question
