Question about HP Color LaserJet 4600n Printer
Kyocera FS 1320D prints dark line down the right hand side
5 Related Answers
Anonymous
SOURCE: black line down right side of paper
On the ADF check the twink mark on glass scanning mirror
Posted on Oct 15, 2007
Leonardo Nogueira
  • 39 Answers
SOURCE: HP 2600N dark gray line down the left side
Maybe your transfer belt is damaged. If u have an spare belt replace it for a test. Answer me if it dont work. Maybe i can get an support manual for u. I work in a HP partner company.
Good luck
Posted on Dec 15, 2007
Rick Kasper
  • 2072 Answers
SOURCE: vertical black line down right side
Did you carefully inspect all through the paper path for some fuzz, or a small piece of paper smearing the print?
The other issue would be the fuser. Do you see any reprinting of images or letters in that area?
What you can do is set the machine to print 2 or more pages and open a cover or turn off the power to jam the prints in the machine. See if the line is on the drum or not. If not then you have a fuser roller issue which would require replacing the fuser.
Posted on Mar 06, 2008
ajay53
SOURCE: Print fading down right hand side
I was able to fix it by taking off the top of the printer. This involved taking off 4 screws on the top of the printer. I then had to disconnect the wires going to the control panel by unhooking them from the right side. I then located a thin rectangular box which I'm assuming houses the laser. I removed this with 4 more screws and turned it over. There was a little metal flap that I moved back and below was the mirror the lasers shoot on before going onto the toner.
In the same spot where I was having fading, I noticed a lot of toner on the mirror, so I cleaned it of, put it back together, and the fading was gone.
This was after I tried a new toner and maintenance kit.
Hope this helps
Posted on May 01, 2008
Anonymous
SOURCE: I have an HP LaserJet 2100 printer and it prints
i have a hp printer and it keeps printing 3 copys but i only need one
Posted on Aug 22, 2009
1helpful
Ip address for kyocera fs-1320d
Contact your IP Provider for the information you require
I need to add an IP address to a Kocera 1320d that has been hooked up as a USB printer, how do i do this?
You can print a status page by pressing for 5 seconds the green button and see what IP address has the printer. Then you can modify it through your PC. The most important is that you have a NIC (network interfade card), because this printer (FS-1320D) comes from Kyocera without a NIC. Unless your printer is already intergrated with a NIC.
How to set ip address for kyocera 1320d
Print a Status Page by pressing the green button for about 5 secs. Check the IP Address on the Status Page. If the IP Address is similar to your local network, you type that IP Address in an internet browser to open the Command Center (web interface).
If it is not similar, then you can change PC's IP to be similar to printer and via the command center, you change the printer's IP to a desired IP (similar to your local network) and restore then the IP of the PC to the one before.
How do I install a new genuine kyocera developer unit (dv-172) in a Kyocera Y FS-1320D?
1-5-4 Developing section
(1) Detaching and refitting the developing unit
Procedure
1. Open the top cover.
2. Open the front cover.
3. Remove the developing unit (with toner container).
4. Check or replace the developing unit and
refit all the removed parts.
5. When the developing unit is replaced with a
new one, carry out the following procedure.
6. Perform toner install mode in the service
mode (see page 1-3-12).
Hi When I try to print a page I keep getting a staggered watermark line down the right hand side, how do I fix this? do the cartridges need to be realigned? maria
As Kyocera FS-4000DN is a Laser Printer, it does not require cartridge alignment. However, the cartridge should be properly seated.
Vertical lines are usually due to the toner cartridge getting old and wearing out. Most often, this issue can be fixed just by cleaning the green drum of the cartridge. Take the cartriddge out of the printer and you will be able to find the line on the drum. Use a dry, soft lint-free cloth to clean it. It may require cleaning more than once thoughout the circumference of the toner cartridge.Secondly, it could be the PCR roller, which is a black roller just behind the green drum. Also, try clean it if possible.
GoodLuck!
Dont forget to rate the solution if I could have been of any help!
CreativeTECH
Whenever our Kyocera Fs-720 printer prints it leaves dark splotchy smudges all the way down the page, any suggestions?
Your printer probably is due for a maintenance clean, which can be done by a certified printer technician.
1helpful
My Kyocera FS-C5030N has just started printing a red line on the right side of every page?
Try cleaning the magenta charge grid on the left side door of printer. But from my experience this is caused by the magenta developing unit wearing out or going bad. A kyocera dealer can help with this.
1helpful
A black line is printing 6.5cm from the right side of the page
Clean the main charge, this is a step that is suppose to be done when replacing the toner but most people don't. The instructions to do this is in your users manual. If you dont have the manual go to www.gfbm.net to download one. Also make sure the cleaner is placed all the way back to the right when done or it will effect your prints.
1helpful
It prints a dark line down the left side of the paper and streaks
One of two common possibilities. Either your drum or fuser needs replacing. You should be able to visually look at the and see if you can see the same type of pattern. Remember to check both the left and right sides of these 2 items, because in many printers, the left side of the page, is the right on the part.
thanks adi
2helpful
Black line on print-outs
When u found any extra black or white vertical line, we can check 3 possibility:
1) check the toner container. U may have to replace a new 1 if necessary.
2) clean the charger wire. Just slide the Charger Cleaner (green color) backward and forward 3-4 times to clean the charger wire, then return to its original position.
3) check the charger cleaner is it in its original position or not?
YBC (/\)
Open Questions:
HP Color LaserJet 4600n Printer Logo
Vinaya Kumar...
Vinaya Kumar...
Ekse
