Question about 5704p 574 Responder LC3 SST 2-Way Security with Remote
Hi I have had the Python 5704P/574 2 Way Alarm / Remote Start with Pager for some time. I recently noticed that pager has badly deteriorated due to wear and tear and needs to be replaced. All buttons are functional but I need a pager housing/case replacement. How can I get one? Thank you
Posted by Curtis on
charles
    New Friend:
  • 126 Answers
Check on ebay or go to the alarm store some remotes can be purchased at part stores
Posted on Sep 26, 2013
5 Related Answers
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: i have a python sst car alarm
usually a combination of 2 buttons so the car doesnt start accidentally.
Depending on the number of output channels - the installer could have installed on any of the channels and that would dictate which buttons to press.
if it is not set on the AUX (output 2) button, then try...
  1. Lock + unlock at the same time - output 3
  2. * + AUX at the same time - output 4
  3. Lock + Aux at the same time - output 5
  4. Lock + * at the same time - output 6
You have not given the model # of the unit - so these are viper's STANDARD remote controm configurations.
CLICK HERE to enter your correct model # and Download your instruction manual.
Hope this helps.
Thanks for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Posted on Mar 01, 2009
Anonymous
  • 146 Answers
SOURCE: My Python 1400XP remote start is killing my
Installation Guide: http://www.abt.com/images/products/BDP%20images/N562P_6-03.pdf
Owners Guide: http://www.directeddealers.com/manuals/og/python/G562P_07-05.pdf
Posted on Oct 18, 2009
Testimonial: "Been looking all over the internet for help with wiring for my remote start. Finally got the answers. Thank you so very much!!!"
Anonymous
  • 151 Answers
SOURCE: python 489p, batt went dead on transmitter,
this may or may not help you with your remotehttp://www.drdetailshop.com/489P.htm
Posted on Dec 27, 2009
Anonymous
  • 68 Answers
SOURCE: I had the brain of my python remote starter/alarm
have it replaced again, that sucks dude
Posted on Jan 24, 2010
logosc75
Larry Spears
  • 625 Answers
SOURCE: The remotes for my system do not operate when I
The "pair" the remote with your system:
1.PRESS AND HOLD the f button on the remote UNTIL the transmit LED lights solid (approximately 10 seconds)
2.PRESS AND HOLD the remote start button (circle arrow) UNTIL the LED blinks 3 times and the amber transmit LED lights up. Your remote is now ready to pair.
3.. Turn the key to the on position
4.Within 5 seconds PRESS AND RELEASE the control button on the antenna.
5. Within 5 seconds PRESS AND HOLD the control button. The status LED will flash one time and the siren will chirp to confirm that the system is ready for remote pairing.
6. Press lock button on remote. System will respond with chirp toconfirm pairing.
Posted on Oct 28, 2010
I have a used 2014 expl intercepter with python alarm. The remote is not functioning due to water damage. I have key to unlock the doors but the alarm will not silence and vehicle will not start.
unlocking driver door only silences a factory alarm. put the python in valet mode until you can get another remote. key on hold valet button for 5 secs and led should glow all the time.
Jan 15, 2018 | Python Vehicle Parts & Accessories
I have a 2007 Honda accord se and I cannot get my car to turn over ive tried disconnecting the alarm system thinking that was the problem and nothing the pager alarm keeps reading inhibit
hybrid or not, what engine I4 or V6, got IMMO? just a clue?
all fuses>? ok? that is first on all elect failure including EFI.
The 2007 and hybrid both have immoblizer options, yours?
pager alarm? after market stuff? hacks? call them...... yes.
IMMO cuts fuel if anyone attempts to hotwire the car (like on TV malarky,see movie PARKER, what a joke.)
The IMMO signals bad key or good key code, does it?
this is in the operators guide , is it lost?
turn over, what does that man.
dead starter motor (dont spin or turn over)
or the engine does not turn over, due to above dead starter?
no crank?
or no start? are 2 different things.
i looked up the IMMO schematic and it does not stop the starter.
it only cuts fuel
so if you mean the engine does crank and the engine fails to sTART.
then check the IMMO responses. if ok. or not.
check for fuel injection
then check for spark;
Sep 07, 2013 | 1998 Honda Accord
My viper alarm rpn 479v p x is not working. When i press the unlock or lock button it doesnt work it just beeps. The remote is also flashing rx. Whats wrong?
I got the Problem that my pager-function doen't work. I try it like the Manual saying (*-Button) but the two ways that gives doesn't work.
- Start the Programmmode while Pressing "P" on the Backside.
- Press the "STAR-Button or Panic-Button (Orange Key) on the Sender"
it Beeps 2 Times. (i try it again with 1 beep as reponse again)
i Wait 5 Seconds
it beeps 2 long times
i try the Responder, Activate the System, disarm the System. But the Pager don't change the state or receive any Signal.
The Transmitter is working perfect! No Problems to control the Viper 690XV.
What i do wrong?
Is there any hidden Feature or needable Programming in the Viper 690XV-Brain?
Thanks alot for any helpful Answer :)
May 02, 2012 | Directed Electronics 479V Remote Gen 2...
Have a Gorilla 8017 2 way page motor cycle alarm The only function that I can not get to work is the communication symbol icon to stay on the lcd screen on the 5 button pager. I did everything according to...
According to your problem first check the battery & you can try by replace the battery. Check all the sensors. Check also the wiring.
May 20, 2011 | GPS
We just realized that the previous owners of our vehicle had already installed a Python 1400XPL remote start system, but did not provide the remotes. I was going to try to program my spare remote from my...
Any valet switch will work. Then simply program your remote. As long as you have a DEI remote there should be no problem unless you are trying to program a two way remote (pager) to a one way system (non pager)
Jan 10, 2011 | DEI Python 1400XP Remote Start/Keyless...
I just got a prestige pager alarm for my car. how do i set the time on the pager remote?
hold down the F button 3 seconds then hit it again to advance to the clock mode, use the lock and unlock buttons to toggle the feature up and down. regards, martin @ lessco electronics
Nov 20, 2009 | APS20B Prestige Keyless Remote Alarm
PAGER
I know Radio Shack used to sell them (pagers), and the service was about $10 a month. It was just a plain numeric display, no-frills pager. Unfortunately, pagers are quickly become fazed out.
There is also a device called the "Firefly", which is a phone, but only dials out to "mom" or "dad" or 911, thus eliminating the chance of racking up a huge phone bill.
You can see it here:
http://www.wirefly.com/zipentry.asp?cid=21427_200faadb9a4c4898b95d3a742c501bfa&referringdomain=wirefly&agent=&e=4&c=&p=&p2=&rp=&action=add&rpid=&p1id=&p2id=&p1pid=&p2pid=&rppid=&dest=&oflag=sfcart&pageid=0&ProductIDs1=&ProductIDs2=&FeatureIDs1=&FeatureIDs2=&CarrierID=62&phoneid=25325
Mar 18, 2008 | Motorola PR96625B Remote Control
E1651742 motorola pager verizon -number #817-227-8133
TAKE IT DOWN TO ANY LOCAL SHOP AND THEY SHOULD BE ABLE TO SORT IT OUT BUT PERSONALLY BE CHEEPER TO BUY A NEW ONE
Apr 12, 2007 | Motorola PR96625B Remote Control
5704p 574 Responder LC3 SST 2-Way Security with Remote Logo
122 people viewed this question
Top Python Vehicle Parts & Accessories Experts
Muntejaya Ginting
Muntejaya Ginting
john h
cartoys4u
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
